Crappy mileage Prius C
Discussion in 'Prius c Fuel Economy' started by ricks06, Jun 26, 2012.
  1. ricks06
    ricks06 New Member
    Rosenberg Texas
    I have read a lot of threads about great gas mileage with the Prius C?? I have a 2012 Prius C with 3700 miles on it and am lucky if I get 45 MPG around town.. My old 2007 Prius wae getting 47 all the time. I am very dissappointed with this C. All of my driving is in the ECO mode and I live in Houston Texas with no hills and drive very conservatively. I don't understand why my mileage is so bad????
  2. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    See DellRio of Iowa's posts in which his problem like yours was solved by a new ecu.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    If you got 47 on an old Prius with old less sticky tires 45 seems appropriate for a new vehicle.
    Since when is 45 crappy?
  4. F8L
    19,011
    4,081
    Grass Valley, CA.
    Let me guess. Short trips under 10miles and the AC is on quite a bit? :)
  5. ricks06
    ricks06 New Member
    Rosenberg Texas
    Since this is a Prius C and supposed to get 51 MPG around town I call 47 MPG pretty crappy/
  6. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  7. F8L
    19,011
    4,081
    Grass Valley, CA.
    You should read more about EPA ratings and their testing procedures. There is never any gaurantee you will get the EPA ratings. Everyone drives differently and in different conditions. I'd love to see someone engineer a car that will get a specific MPG number in any situation at any speed all year round. LOL
  8. PriusCinBlack
    PriusCinBlack Member
    145
    61
    Rick, I sympathize. You should be getting better mpg than that- in theory- around town. Try driving around town for a half-hour and see what happens from there. Make sure you're using the right techniques, though.
  9. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Wonder if any of those 30+ highway MPG advertised cars ever get slammed for never getting that number...
  10. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    The C is a bit different from the Gen II you are used to. You might look up Wayne Gerdes videos on how to interpret and use the HSI.
    Like this one:
  11. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Take it out of ECO mode, drive way across town and back to be sure everything is warmed up, use all you have learned about driving a Prius, and be in tune with the differences of the C. By your mileage, you should have learned what the C likes by now.
    A/C is a real gas sucker. Turn it off and put your windows down in town. See how much that helps.
    The most important thing I've learned about the C is to back off the gas pedal a lot to get the car into EV as much as possible, and to work that EV as long as you can. It doesn't glide like our '09, so it is somewhat different.
    The other most important driving tip I have is that the Rearview Mirror is very important. If there is nobody behind you there is no pressure to speed up at all. If the person behind you is close and stays there it probably means they're either about to pass you or they're about to turn right. Either way, they will take care of themselves before long and remove any pressure you may feel. I pretty much ignore them either way.
  12. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Your Gen 2 is a great car. The c has a lot to live up to.
    When FE is below the previous Gen I call it crappy as well. Rick, I believe upgraders are at a disadvantage compared to Newbies as we already learned what to do & when to do it. The problem is that the new car is different. The feel is different, the transition points are different... You're probably doing the right things but at the wrong times.
    Are the tires different? Check & adjust the tp. If you were running max sidewall on the Integrities are the new tires at max sidewall? That was easy.
    Gas may make a difference. My 2006 seemed to like Shell. I know it's a feeling that I can't prove. The 2010 does not like Wawa. It absolutely had no power & felt like it couldn't get out of its own way. It's run fine on mostly Citgo, but also Gulf & Shell.
    The displays are different. That which was useful isn't now. I use the HSI exclusively but we don't have the same dash so I don't know what will work for you.
    It took me the longest time to adjust to the different feel & transition points. There are a couple really good Gen 3 vids that I watched over & over again. Maybe there are c specific vids available.
    On the HSI being in the left side of the bar keeps you on the battery (as long as the ICE is hot enough & the SOC is high enough). When I get into the right side the ICE kicks in & instantaneous FE drops. It stays "low" until the pedal comes all the way up. Remove pressure for a split second & reapply but a bit less.
    You've got some 5 years worth of habits to unlearn but one day everything will click & that which you weren't able to do at all becomes instinctive. It's going to be frustrating as all He!! in the meantime but hang in there.
  13. DC ebikes
    DC ebikes New Member
    24
    Pittsburgh
    This is my first Prius and I love it! I watched a few P&G videos before I bought it, so I basically try to glide as much as I can and stay in EV mode as much as possible. I've done a bunch of out and back commutes of >60 miles at indicated 62-66 mpg. My fill up today was a calculated 60.5 mpg over 414 miles. The car is great, hope it all comes together for you!
  14. ricks06
    ricks06 New Member
    Rosenberg Texas
