Two vital questions
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by schmultzburger, Jul 2, 2012.
  1. schmultzburger
    schmultzburger New Member
    Near Albany, NY
    Hi all. We are considering trading in our '04 Prius with 165k on it for a new one. The plug-in looks like a good option for us except for two concerns...
    1. Are there longer plug-in cables/tethers/cords (not sure what they are called) available? I live in the city with with a narrow lot and a tiny garage that is useless for vehicles. The only place to park the Prius is behind the lightly used minivan, in the single-width driveway. The van is rarely parked right up next to the garage door either as we need space to get the bikes out (my commuter vehicle of choice) and (in winter) give room for the snow/ice slide off the slate roof from damaging the vehicle. So I'm looking at an easy 30 feet minimum to get toward the back of a Prius.
    2. Does the Prius console clearly show when the car is plugged in or is it prevented from starting up or being put in gear? The plug in side of the Prius parked in our driveway would be away from the front door and I just know I would come running out to get somewhere quickly, jump in and not notice/forget to check that the Prius was still plugged in. I undoubtedly will attempt to drive away while still plugged in. I suspect that is a bad thing.
    I appreciate any answers or suggestions you have to offer.
    S-
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I just use an outdoor extension cord, I think it's a 12 gauge. No problems.
    There is a light which lights up right next to where it plugs in while it is charging. When done charging it goes off. But that doesn't matter since iIf it is plugged in and you get in and try to engage drive reverse etc, it reminds you you are plugged in and will not engage the gear. Also, if you are unplugged but forget to shut the charging door it'll remind you also of that being open and not properly closed.
  3. bisco
    49,397
    2) it will not start when plugged in. 1) can you have an outdoor outlet installed next to the driveway near the back of the car? you can use an extension cord, but you have to be careful about the size.
  4. schmultzburger
    Near Albany, NY
    Does the extension cord plug directly into the Prius, or do you plug the special cable/tether (What is that thing called?) into the extension? Assuming the latter, my concern is an unprotected electrical connection laying on the ground during rain/snow/whatever. I was assuming I would install one of the Leviton charging stations, but the cord is too short (from what I can tell).
    Here's a thought... Is it possible to replace the cable for the Leviton charging stations with a longer one? Can the box and head be dismantled to rewire it myself?
  5. schmultzburger
    Near Albany, NY
    That is unlikely. That side of the driveway is about a foot from the property line, and is where all the snow from my and the neighbor's driveway gets piled (over 6, hard-packed feet two winters ago).
  6. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
  7. schmultzburger
    Near Albany, NY
  8. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    I already posted this, but I have a situation like yours. I installed a dedicated GFCI circuit breaker and ran new Romex to a new, weatherproof outlet on the side of my house. Then I put some hooks in to hold it.
  9. CharlesH
    2,785
    1,152
    Roseville, CA
    But this is a "soft" reminder; the car will still operate normally with charge door open, as long as you are unplugged.
    bfd likes this.
  10. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    How well do I know that one! There is a serious disjuncture in my routine when it comes to unplugging and closing that door. You would think it would just be that easy, but for some reason, I can't make that move: Unplug, close door. For whatever the reason, I miss more times than I get it done.
  11. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Yes, I did not mean otherwise, should I have mentioned that? If someone wants to drive around with that long message displayed on the screen, well... :LOL:
  12. bisco
    49,397
    i drove my wife to the gas station to pick up her car the other day with the charge door open all the way. i never noticed the message.:whistle:
  13. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    :cautious: So it happens I guess Bisco lol
  14. bisco
    49,397
    mia culpa. it's a good thing you can't start it whilst plugged in or i'd have already dragged half my garage down the street.:D
    Tracksyde likes this.
  15. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    I use an extension cord that I picked up from Lowe's. I asked my electrician what gauge to pick up.. it is a thick extension cord that is heavy to lug around. Sometimes I take it with me not knowing how far I will be from a plug.
    As for weather issues... make sure your electrician installs a GFCI on the outdoor plug.
  16. ukr2
    ukr2 Senior Member
    1,009
    275
    31
    Victor, NY
    Bisco,
    I tested my PIP.
    I can't put it in gear when the plug is still connected.
    After removing the plug, I can put the PIP in gear and drive away, but the display shows "Recharge Inlet Door is Open". You can change the display to another screen, like HIS, but the message re-appears every time you change gears.
  17. schmultzburger
    Near Albany, NY
    That looks nice, but I'm already planning on installing a GFCI, weather-proof outlet at the closest corner of the house. I need an additional 30 feet or so from that point. I had figured I'd get one of the Leviton "home charging stations" until I saw the price!
    How long is the charger cord in your picture?
  18. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    That's the charger which comes with the PiP, and it's approximately 24' in length.
  19. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    What does Toyota say about the car with charger plugged in sitting out in pour rain? Do they say the connection at the car is waterproof or the charger? I'm thinking of running 300 feet from the house in mining cable and mounting a charger in my parking spot but started wondering about the car mfg. saying this was not safe.
  20. Rebound
    3,964
    2,613
    Portland, OR
    The cable that comes with the car is safe in rain, assuming that the 120V outlet meets electrical code. Code varies by locale, but usually states you have to have a GFCI circuit or outlet, and the outlet has to have a weatherproof cover. The manner of running the cable from the breaker panel to the outlet is also prescribed by the code, and it depends on whether it runs through a wet or dry location, above ground or under.
    It's NOT complicated; you're not memorizing the whole electrical code. You can like explain what you want to do to your city and they'll tell you exactly.
