Blind Spot Monitoring
Discussion in 'Prius v Audio and Electronics' started by hoddy4, Apr 8, 2012.
  1. hoddy4
    hoddy4 New Member
    118
    NC
    The Camry Hybrid has an option for Blind Spot Monitoring where an image is displayed on the side mirrors. I don't believe that any of the v models have that option. Is it possible to add that feature in the after-market?
  2. sparkstack
    sparkstack Car Addict.
    Illinois
    Yes. It's called E.Y.E.S
    Adjust the mirrors correctly, and use them.
    Fil Factor likes this.
  3. russcarver
    russcarver Junior Member
    91
    Erie, CO
    That's right! While driving, adjust the side mirrors such that when the nose of a car behind & next to you disappears in the rear-view mirror, it appears in the side view mirror. When set correctly, the the car will then appear in your peripheral vision when it leaves the side mirror. The result: no blind spots! I have no idea why people turn their side mirrors to see their door handles. You're just overlapping the view your rear-view mirror already sees!
    --Russ
  4. Fil Factor
    Fil Factor New Member
    Wisconsin
    Well said. I've posted this in another thread. We were not taught in driver's ed how to correctly set our side mirrors, and old habits are hard to change.
  5. c64rbr
    c64rbr Junior Member
    Houston, TX, USA
    This is an aftermarket blind spot warning system installed on a regular prius. Thinking of installing one. The materials can cost $200-300. DIY to save a ton on labor.
