curious....your top speed?
Discussion in 'Gen 3 Prius Main Forum' started by has been, Jun 10, 2012.
  1. walter Lee
    1,126
    376
    Maryland
    2012 April
    80 mph (as tracked by a Garmin GPS unit)
    81 mph ( Prius speedometer)
    2010 Toyota Prius III with Yokohama Avid S33 tires (38 psi front 36 psi rear, probably should have been 4 psi higher)
    48 mpg over +400 miles as estimated by the Prius MFD
    44 mpg over +400 miles as calculated at the pump using 10% ethanol 87 octane gasoline
    Road = Illinois and Ohio's I-70 (eastbound), speed limit 70 mph, raining/road surface wet 100% of the time.
    90 mph will get you pulled over by a state trooper.
    comment: the Prius drives and handles very smoothly @80 mph, the Yokohama's provides very good traction.
  2. priusrick
    priusrick Member
    257
    40
    I've gone 85 a lot. texas driving
    VM670 ? 2
  3. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    2010 limited to 112 too
  4. bwilson4web
    16,335
    Tailwind, ~10 mph?
  5. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    95 mph in the mountains recently, very stable.
    For people who experience some instability at > highway speeds, even with the stock 15" tires, I'd suggest getting the alignment checked.
  6. walter Lee
    1,126
    376
    Maryland
    While the storm system that I was driving through was moving eastward in the same direction I was going -- the storm system wasn't moving very fast so I didn't noticing any tailwind.
    bwilson4web likes this.
  7. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Mine did 95 without any issue.
  8. oldasdust
    oldasdust Member
    356
    47
    illinois
    80's multiple times on an expressway in open areas, 90 once no issues other than big drop in mpg.
  9. LARRYG36
    LARRYG36 Member
    123
    45
    Southern Nevada
    94 mph, and it was Scarey as Hell !!:eek:
    ** w/Factory Tires/Rims
    ** With the new Rims/Tires we cruise at 80-85mph on the Hwy all the time and it feels like we're doing only 40mph.
  10. Mikawa
    Mikawa Junior Member
    32
    Rancho Palos Verdes, Southern California
    I love that PWR button!
    I was doing 64 on the freeway, mashed that button and I was up to 81 in a few seconds! Wohooo!!! I think I saw the pick-up driver's jaw next to me drop to his lap.
  11. Manila Ice
    Manila Ice Hybrid and V8 Lover
    96
    63
    Chino Hills
    check this out:
  12. markabele
    5,084
    1,782
    Nebraska
    How fast were they going?
  13. LM-HSD
    LM-HSD New Member
    Portugal
    The Prius is limited at 180km/h (112mph). At that speed, the speedometer shows 196kph (122mph). Glad the Police was not around that day... :whistle:
  14. Ragz
    Ragz Active Member
    210
    110
    New York
    My top was 94 going uphill. Felt fine
  15. markabele
    5,084
    1,782
    Nebraska
    Nice! Love that you are still getting about 25 mpg!
  16. DonJuan1943
    DonJuan1943 Member
    64
    53
    Northern Illinois
    Last week on The Pickle Parkway (toll) near Austin Tex.(speed limit 80), I had the road to myself and easily got up to 100mph (light wind, 86 degrees F, tires 36psi). Car handled beautifully, but I got "handcuff fever" and chickened out, returned to 80mph.
  17. PearlJammer
    PearlJammer Member
    112
    Georgia
    2018 Prius
    108.....on 17's... smooth as silk. Felt like it could do more. Very surprising...like most features on this car. Makes me love it even more.
  18. That_Prius_Car
    That_Prius_Car Austin Kinser
    1,282
    344
    Pittsburgh, PA
    I have an app on my phone that uses GPS to determine speed. I topped out my 06' Prius at (the speedometer in the car said 109) but my GPS device said 107mph and stayed at that speed for several miles with my foot all the way down to the floor. My current MPG meter on the Energy Monitor jumped from 22-34mpg, then my battery started to drop and I let off. Rode smooth, I have good tires, and the fact that the Prius is so aerodynamically stable helps a lot.
    In my old 01' Prius, it topped out at 101mph as stated by my speedometer, but realistically, I think it was about 99mph when it stopped accelerating. Drove about 5-6 miles at top speed (flat roads in Illinois with no hills or curves) and then the battery dropped to the point where it wasn't assisting anymore, my Energy Monitor showed that the engine was powering the wheels, while sending power to the electric motor, which was also helping power the wheels, but the battery was just on stand-by, then the speed started to drop and it held steady at around 97mph (really about 95mph) but occasionally, it would take a second and it would pump some juice into it. Didn't check to see what MPG was at that speed though.
    The Gen.III Prius, Brad and I owned one for just over a year before he got the Volt, and I topped it out religiously. 116mph as read by the speedometer, but I think it was more like 113mph. And no matter what the battery level was at, it held the speed and didn't drop unless you went up a small hill.
  19. That_Prius_Car
    1,282
    344
    Pittsburgh, PA
    This is the top speed video of my old 01' Prius.
    This is the top speed video of my current 06' Prius.
    and last but not least, the 2010 Prius top speed video. & for some odd reason, it didn't hit 116mph like it usually did. Maybe because I was going up a hill?
    Also, keep all your negitive comments to yourselves. In all the videos, I made sure to keep people and other drivers out of harms way. I did these on un-populated roads. Never the less, I know it's still dumb, so save your breath.
    striker308 likes this.
  20. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    My Gen II (Picking up the new Gen III tomorrow) Normal highway speed of between 75 and 85 for my daily commute feels the same as 55 for handling but my MPG drops from 47 to 42. The fastest I have had it was on my wedding day (yes, I was late) and that was 118 MPH on interstate 90 (I-90 or for the western NY folks “the 90”) I was still gaining speed but had to slow down for a Canadian driver in the left lane that seemed to think that 70 in the passing lane made it ok to hold up traffic for 14 miles before he finally understood the left lane is a passing lane. (This is normal of our northern friends on the 90) It handled great at that speed, didn’t sway, bounce, or drift and had OEM suspension at that time. The fastest I have had a gen III so far was 75 mph during the test drive.
