Fuel Economy diagram with and without Air Condition
Discussion in 'Gen 3 Prius Fuel Economy' started by BlauerClaus, Jul 7, 2012.
  1. BlauerClaus
    BlauerClaus New Member
    Hi - I'm new in this forum. I'm from germany and infected by the Prius Virus. I have seen lots of discussion about the fuel economy and I found a fuel consumption diagram for the Prius I. But there is no Prius III fuel economy diagram around. How to make it?
    Thanks to Wayne Browns recently published genial Prius III simulator, I found a way to make it. Lots of work, hundreds of values, manually transferred to Excel - but the result was it worth. The results of my simulations with and without air condition will be posted here step by step. I have made a US version with mpg and °F, and another version with °C and l/100km.
    Germans may look here: Prius III - Verbrauchsdiagramme mit und ohne Klima - PRIUSforum
    Best regards
    Rainer
  2. BlauerClaus
    Next step is the consideration of the Air Condition. I have set the inner temperature to 24°C or 75.2 °F respectively. Here is the diagram. Interesting: the fuel economy has its sweet spot in typical city traffic.
    Best regards
    Rainer
    bisco, JimboPalmer, F8L and 1 other person like this.
  3. BlauerClaus
    And what is the additional fuel consumption? The following diagram shows the substration of both diagrams. It represents the "additional consumption" caused by Air Condition. Especially interesting is the additional consuption for cold temperatures.
    Best regards
    Rainer
    JimboPalmer, F8L and walter Lee like this.
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    Interesting information. This does not differ much from my own anecdotal observations while on the street.
  5. bisco
    52,386
    thank you rainer, that looks like a lot of work! well done, you must be bob wilson's german cousin.:)
    cwerdna likes this.
  6. Cvk14
    Cvk14 Junior Member
    37
    New York, NY
    Am I read that correctly, that essentially keep the AC off until you reach steady highway speeds, then its really no loss to turn it on?
  7. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    Not only that ... the biggest lesson is that A/C (cooling) is a lot less an affect then heating (especially when you are not going full power highway speed!!! Although, I do not know about you, I would not consider setting 75.2 F the heater during winter time !!!
    This is why grill blocking is a BIG help in the winter under especially low load/speed.
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
    No, just drive with them down until the cabin cools off some then turn it on. If the cabin is hot then you are going to suffer a big mpg hit regardless of how fast you go. The important take home message is keep the cabin cool, use the A/C sparingly (temp 78F or higher), and pre-cool the car by driving with the windows down for a few mintutes before turning on the A/C. How to Reduce MPG loss Because of A/C Use | PriusChat
  9. prj
    prj Member
    OH
    Older cars would run the A/C full blast, then add heat from the engine to adjust the temperature coming out the vents. I used to have to rev the engine in my old Integra to get a decent amount of cooling, since the A/C compressor speed was tied to the engine speed. It had minimal cooling at idle.
    The electric A/C in the Prius doesn't depend on engine speed. It works just as well when the engine is shut off.
    The Prius will reduce the power used by the A/C when the temperature setting is raised. Even a high temperature, maybe 78+, will still reduce the humidity, which helps a lot.
  10. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Note that it's easier to see the effect in the German link because they show it in l/100km. For showing difference in consumption we'd be better of with gal/100mi instead of mpg since the difference in mpg depends on the starting mpg value so you can't really see how much each number is really worth in terms of consumption.
    Anyway, remember that A/C use depends on time. So, it's only "better" to wait if your fuel cost is higher per minute. From the l/100km graphs it seems it could be slightly better, but having only 1dp in the l/100km it's not clear how much.
    For example, at 20C, 30km/h it's 0.3l/100km more but at 60km/h it's 0.1l/100km more. Of course, if the numbers are rounded it's possible there's actually no difference in consumption/minute.
  11. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    LOL! I hope he sees this thread. (y)
  12. Brett.
    Brett. Junior Member
    134
    26
    Great work, it's good to see somebody putting in the time to chart things. While the numbers look good for the parameters you have posted, the parameters themselves are "ideal" and not likely. Smooth roads, 0 wind? lol Not here.
  13. BlauerClaus
    Hi again - thanks for all your positive feedback. I have prepared another set of diagrams for you. After the initial diagram with AC on I though we could optimize it manually. As you said, in hot days, we will probably not go with 75.2°F but increase it, maybe to 82.4°F. And in cold winter we probably can live with cooler temperatures around 60.8°F. Look at this diagram, on the rightest column you see the temperatures I assumed. Interesting: the sweet spot is broader in all directions.
  14. BlauerClaus
    If we now compare the optimized climate control usage with the fuel economy diagram without air condition, we see the additional fuel consumption caused by the air condition. It is calculated by the subtraction of the previous diagram and the first diagram without AC. You see, the savings are significant with optimization. Hey Toyota, could you embed this into your climate control system? It could be called "ECO climate control system". Maybe they already do, I don't know.
    Best regards
    Rainer
  15. BlauerClaus
    Now lets see the efficiency increase due to the optimization. Look at this diagram and decide yourself if it is worth to manually manipulate the AC control temperature while on the road or not.
    Best regards
    Rainer
