Formal apology to 2012 Camry styling
Discussion in 'Toyota Hybrids and EVs' started by mmcdonal, Sep 26, 2011.
  1. cossie1600
    cossie1600 Active Member
    898
    92
    CT
    I just got back from driving the Camry Hybrid. I can't believe I bought into all the hype. While the car was good, but it certainly isn't much better than the Prius. Matter of fact, I would argue they come in pretty much the same in overall grade once you consider everything.
    Here are the things I like
    Like
    #1 HSD. The new engine is awesome. It is WAY faster than the 3rd gen Prius, it is WAY quieter, but at the expense of about 10mpg in my brief test.
    #2 Engine and road noise seem to be way down compare to the Prius
    #3 More shoulder and head room front and rear.
    #4 Great price for what you get
    Dislikes
    #1 Ride. The ride is better than a Prius sure, but it isn't great. I felt every pothole and bumps on the road.
    #2 Trunk space is marginal for a giant car like this one, small pass thru instead of a complete fold down seat.
    #3 Rear seat position. While you get more space and everything, but the rear seat actually sits lower than the Prius. I felt like I have to spread my legs in order for me to put my foot flat on the floor without my knee caps going higher than my nuts
    #4 Driver seat position is even worse. The lack of adjustment on the front side of the seat bottom blows.
    #5 The car is HUGE
    With everything said, I would still recommend the car given the price (I can get it for $1500 off sticker). For me personally it is a a big no. On the other hand, the Highlander is way cheaper than the RX450h and the MDX that I was looking at, very tempting
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Trunk space is larger with the conventional Camry and the rear seat does fold down, not just a pass thru.
  3. bisco
    49,821
    if you think that trunk is bad, you should see the first gen. the new one is much larger.
  4. TxMan
    TxMan Hearse driver
    The Matrix
    my car is probably about 24 feet long.
    you ever drive a big car? (camry doesn't count)
    like a GM B chassis? ford Panther Chassis?
    you learn your corners REAL fast, the size of the vehicle makes no difference after a week of driving.
  5. cossie1600
    898
    92
    CT
    I seem to recall the early 2000s ones had a bigger trunk. To be fair, this was a hybrid so it does suck to have to deal with the loss in space.
    I have driven plenty big cars, it doesn't mean I like it. I just think the car is pointlessly big. It's bad when a 7 passenger seat is around the same length as the Camry.
  6. crebble
    crebble Member
    176
    47
    Shohola PA
    I plan on taking an XLE Hybrid for a test drive while my Prius C is in for its 10K maintenance. Dealer has 5 in stock with the leather package. Heard good things about the seat comfort. The Prius C seats hurt my wife's bad back after about 30 minutes.
  7. firepa63
    1,761
    208
    The Camry is a lot more comfortable than the Prius. That's why I traded my Prius and went for the XLE Hybrid. However, both my wife and I found the cloth seats more comfortable than the leather. The cloth seats seemed a little softer (to us).
  8. TxMan
    TxMan Hearse driver
    The Matrix
    I have never liked Camrys...they always felt...light, cheap, unsafe, underpowered, 'loose' and just not a solid, powerful car that I would drive for any length of time. I think it was an '02 or '03, I had it as a rental car.
  9. firepa63
    1,761
    208
    There's a big difference with the '12...
  10. Tideland Prius
    16,211
    Funny. We had an '02 and at that time thought it was a pretty darn good Camry (XLE 4-cylinder). It weighed 1,500kg (base model of a '12 is close to that weight). I would agree with "loose". That steering wheel is "one turn of a screw" away from one-finger-steering.
    My favourite Camry is still the '92-96 design, particularly the '92-'94 in Dark Emerald Pearl.
  11. bisco
    49,821
    i've never had a 'fancy' car, but the camry was the smoothest, quietest, fastest, most comfortable car i ever owned. first one was an 02 i believe. and the genI hycam is 25% better. i can't imagine how nice the genII is. we rented a fusion in cali for a week, didn't come close to the camry imo.
  12. TxMan
    TxMan Hearse driver
    The Matrix
    it might also just be me, I am used to being around heavy trucks, and much older cars...like, dash of steel cars...the newer cars I am around are like mercedes, and no one can come close to one of those.
  13. Tideland Prius
    16,211
    Can't compare to the European cars. They still have that "tank" or "vault" like feeling every time I ride in them. The Japanese cars still can't match it imo.
  14. TxMan
    TxMan Hearse driver
    The Matrix
    ^I know, right?
    I had to work on an '05 lexus sc430, which is a blatant rip off of a Mercedes CLK...my coworker has a CLK, like an '03, has a 3.0 V6, not a race car, but still a great car.
    anyway, the lexus felt cheap, and not...right, I guess...the suspension was too firm for a luxury car, but too soft for a driving car, the engine, despite the displacement, had almost no torque, and reliability can't be that great, it spun a cam bearing (still trying to figure this one out) at 47k, and grenaded the rest of the motor. (loltoyotaV8)
    also, the Mercedes was SO much faster you put your foot down, and that sucker GOES, no questions asked. but when you weren't driving aggressively, it was smooth, controlled, comfortable, and still felt poised and ready to go...
    tl;dr, they shouldn't have tried in the first place. Mercedes spends a million a day on R&D, there is a reason they are WAY better.
  15. bisco
    49,821
    yes, you're definitely comparing apples and oranges. i used to drive the big '85 mercedes diesel sedan. 300sd i think? LOL, talk about a load!
  16. TxMan
    TxMan Hearse driver
    The Matrix
    ^I would love a car like that...had I had more notice on my car search, I would have loved something like that.
    also, in high school, my friends parents had one that had like 400k on it...I think they still own it
  17. cossie1600
    898
    92
    CT
    I test drove the car. I love the engine as it is much more powerful and smoother than the Prius, but everything else is boring and blah
  18. TxMan
    TxMan Hearse driver
    The Matrix
    could be a nike commercial
