Prius MPG is a scam when compared to tire waste
Discussion in 'Gen 2 Prius Main Forum' started by diode, May 13, 2004.
  1. diode
    diode New Member
    Rohnert Park, CA
    I just bought a slightly used 2003 Prius with 7500 miles on it. The front tires are already worn down to the wear bars.
    I contacted Bridgestone and Toyota and both explained that because of the heavy loading and the small tire, the tires will wear at a very fast rate.
    A local Bridgestone dealer says it is not uncommon for him to replace tires at around 17,000 miles (This from a 30,000 mile tire) on a Prius. Toyota also states this is the ONLY tire I can use.
    At $400 a set, this could mean someone who puts allot of milage for a year needs to spend an extra $400, plus the extra rubber waste which cannot be recycled.
    Did they improve this on the 2004 Prius? For me trading one waste for another doesn't make the car any more a green vehicle, efficient or cost effective. For example, my 1998 Olds which gets 22 MPG, but I can keep a set of tires for 70,000 miles, and they cost about $250 a set.
  2. Price Taylor
    Price Taylor New Member
    Greater Seattle, WA
    Diode, you might want to go out to the Yahoo group for the previous generation Prius.
    Indeed, there were problems with the low resistance tires installed on the 2001-2003 Prius. What I don't know off-hand is what they did about it.
    Perhaps John1701a can give you some input as well.
    As for the 2004 Prius, the Goodyear Integrity tires aren't great but after 11K miles at 40/38psi (front/year), they still look brand new. They do pick up a fair about of road noise.
    Price
  3. john1701a
    john1701a Prius Guru
    12,831
    5,308
    58
    So just buy a different tire.
    Long ago the classic Prius owners found alternative tires that last 40,000 to 50,000 miles... perhaps more, but not many have driven that far with them yet.
    When I sold my 2001 Prius, my alternates were just shy of 30,000 miles. They looked fantastic still. Without any doubt, they would have easily exceeded 40,000 miles.
    Buy a better tire. Here's a few (of many) suggestions...
    http://john1701a.com/prius/prius-tires.htm
  4. naterprius
    naterprius Senior Member
    1,843
    diode, did you have the alignment checked? If the toe is off you can have severe, premature tire wear.
    Be sure to get a four wheel computerized alignment. Do it the same day you buy new tires.
    Nate
  5. jsorger
    jsorger New Member
    97
    Toyota replaced all 4 tires on my family's old Prius for free (about a year after it was bought). They mentioned that they found some sort of problem with the tire design.
  6. daniel
    14,487
    1,519
    Spokane, WA
    Say, John, do you have a page of similar information for the '04 Prius? Specifically I'm wondering if I ought to change the tires on mine, and if so if I should go with an all-season or separate summer and winter tires. We generally get colder temps but less snow than you do.
  7. jchu
    jchu New Member
    1,063
    Nampa, ID
    Also my understanding was that the primary engineering goal of the Prius was not mileage but emissions. The MPG boost was a nice add-on benefit (and obviously more marketable in the US
  8. Wolfman
    Wolfman New Member
    1,233
    Williston, ND.
    If you still have OEM rubber on the classic Prius. Run the tire pressures at 44 front, and 42 rear. Ride quality is not affected, according to my seat of the pants feel, and I have almost 21k on mine. They are still looking great. My only problem with them is a bit of noise from when I ran it for a couple of days out of alignment, after hitting a dead dog or coyote in the middle of the road that I couldn't avoid.
  9. john1701a
    12,831
    5,308
    58
    Nope, and I likely won't either. There are so many choices available for the 2004, it simply isn't necessary.
    With the classic, that was different. The reason is those tires were only 14", which is far less common than the 15" the 2004 uses.
    As for my opinion on the tires, I've come to the conclusion that I'll be replacing my 2004 tires (right before the start of the 2005/2006 winter) with the same alternate tires I used on my classic... unless someone finds something better in the moderate price range. The rode a little better, were a little quieter, had deeper tread, and worked as if they were LRR (no MPG drop).
  10. edmcnierney
    edmcnierney Junior Member
    What makes you think used tires can't be recycled? It's done all the time.
  11. petteri
    petteri New Member
    203
    Plantation, FL USA
    Yes, but of these 15" tires how many are LRR tires?
    Peter
  12. daniel
    14,487
    1,519
    Spokane, WA
    In other words, you are satisfied with the OEM tires, if you do not plan on changing them for a year and a half. I guess that answers my question. Thanks.
  13. siai
    siai Junior Member
    Florida Keys
    If only the front tires were worn to the wear bars and not the rears, it is most likely toe in adjustment and the fact that nobody rotated the tires. I have had two classic Prius' and by running 44/42 tire pressures I have had no unusual tire wear problems. Diode, I hope you come back to read the replys to your post as tire wear on the classic is not that much of a problem. Enjoy your new car :D
  14. diode
    diode New Member
    Rohnert Park, CA
    Efficiencies?
    Thanks all for the information. So this group is for 2004 Prius only? A friend of mine got the 2004 and he gets worse gas milage than what I get.
    Here is some interesting information:
    Most tire shops will NOT install tires which aren't listed in the vehicle specs. This tire is the only one listed for this car.
    The tires did not have premature or uneven wear. In addition I received all the service records for this car and it shows rotations at 3,000 and 8,000 miles.
    Some Toyota dealers say that it is okay to run the tires no higher than 40 PSI.
    Toyota says to get the best safety and performance, use the tire pressure listed in the glove compartment. To the best of their knowledge, there are no bulletins on increasing the pressure.
    I found Costco to be very valuable. They have the same exact tires (I had to special order) for only $269 installed for a set, and they have a 40K warranty. Costco will also pay you cash for your unused tread.
    Bridgestone claims that they don't offer warranties on OM tires shipped with new cars, as that would be covered in the new car warranty. Toyota says that the tires are covered by the manufacturer. Oh well.
    BTW when I said the tires aren't recyclable, I know of course they are, but I would be producing two to three times the amount of waste to be recycled. Also I don't think used tire rubber can be used to make new tires.
    If they designed this car to use a wider tire, it wouldn't burn through them, and the milagle would probably be the same as a civic.
  15. Danny
    Danny Admin/Founder
    7,093
    2,122
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Re: Efficiencies?
    No, this site is for all Prius Owners & Enthusiasts - most of the discussion does have to do with the 04+, though.
  16. Jim S.
    Jim S. New Member
    39
    Pasadena, CA
    I wouldn't take the "they still look great" at face value-- when my tires on my '01 went (at 28K), I'd been warned about the problem, but whenever I looked at the tires, they seemed ok as well.
    My first indication that they weren't ok was when I realized I had a flat on my left rear tire, and when I looked at the others, they all needed replacing as well. Guy at the tire shop thought it was an alignment issue, which ticked me off because the car was at the dealer not a month earlier, and they were supposed to have rotated the tires, but when they put it on the machine, it checked out fine.
    Moral of the story: first gen tires can go from fine to wrecked in around 1-2K miles.
    The happy ending: got my '04 before I put more than 5K on the new tires :)
  17. eak354
    eak354 Member
    447
    HI
    I dont/didnt have the classic prius but my sales exec mentioned the tire problem. because of the size, availability was the major complaint of owners, they are not readily available and need to be special ordered, hence the price. they resolved this with the '04 by using a more common tire.
  18. m4prius
    m4prius New Member
    59
    Ohio
    John will you switch to the Nokian NRT2 for winter...if so will you use steel rims instead of the AL Wheels??
    Mike
