1. Dusty Chips
    Dusty Chips New Member
    85
    Laughlin NV
    Plenty of battery charge, fully warmed up, not going too fast (parking lot speed).
    Still won't go into EV mode. No light, WILL go inyo ECO mode; Power mode.
    Ideas?
  2. cmezriczky
    cmezriczky Junior Member
    34
    Austria
    Hi. You have set 2011 Prius in your account info and now post in the Prius C troubleshooting forum, so I don´t know if I give you the right infos. EV Mode often ends on 3Gen Priuses at sudden acceleration, so you have to be extra smooth on the Gas-Pedal... Might also be the same on Prius C Models...
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    Is it not going into EV Mode or do you simply have the dash light turned off? There is a setting for that on the 2012. I'm not sure if earlier models had that setting.
  4. Dusty Chips
    85
    Laughlin NV
    Ooops...
  5. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
  6. etobia
    etobia Member
    116
    NEW YORK STATE
    Ok moderator........where did this persons post get moved to?
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Ok etobia. ;) It was in the Prius c forum. It is now in the Gen III forum since he doesn't list he has a Prius c. It was kind of explained in the 2nd post where it was posted originally and it can be seen now where it currently is.
