POWER MODE
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Andyprius # 1, Jul 10, 2012.
  1. Have not experimented much with PM so I thought I would try it out this morning. It is incredibly fast, incredibly efficient and thus far I see no decrease in mpg. On a 7 mile return from shopping mall I had 116 mpg. What is even more surprising, on regeneration the bar shows more. About twice as much! Driving very aggressively today, ( not my usual habit ) Taking everybody at the light, and changing lanes at random, I think possibly the younger crowd hates that, especially with handicap plates on my PIP. After slowing down for a 30 mile curve, I allowed him to pass me, but with his poor logic he took the blind curve at 50 plus and almost ran a red light at a major intersection. Tomorrow, I will keep the car in power mode and drive conservatively and see if there is any difference. How about you? Have you tried Power Mode?
  2. Johnny_D
    Johnny_D New Member
    That is funny. Had to look twice to make sure you were talking about the PIP.
    Btw, you can go into power mode anytime by flooring it. I just keep it in Eco or Ev.
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    It's all in how you drive it. Personally I find it hard to hypermile in Power Mode. The RPMs shoot up too quickly because the throttle is overly sensitive. Eco Mode will hold an advantage when using A/C heavily. Otherwise use whatever mode works best for your driving style.
  4. I think you are right there, I actually never take it out of Eco. Also that was with The AC set on 78 degrees. Lifetime average on trips A and B is 88 mpg.
  5. qbee42
    3,082
    Power mode isn't any faster than any other mode. It only changes the feel.
  6. JamesCSmith
    JamesCSmith New Member
    59
    So then it must "feel" faster :)
  7. CharlesH
    2,798
    1,166
    Roseville, CA
    All Power/Normal/Eco mode do is vary the mapping from how far the pedal is pushed to how much power the control computer will command from the ICE and/or the electric motor. One end of the range is zero ("idle"), and the other is flooring it, and these end points are fixed power values. It's the values in between that are tweaked. In Eco mode, the pedal is less sensitive at the low end, and the other way around for Power mode, and normal mode is in between. Eco mode also does something to the A/C to make it less power hungry, but that is pretty much it. So one can leave it in Eco mode, confident that in a panic situation, flooring it will get the you same power as if you floored it in Power mode.
    Andyprius # 1 likes this.
  8. qbee42
    3,082
    This same technique has been used for years for normal cars. Honda is a good example: they map most of the throttle response to the first few centimeters of accelerator pedal travel. You touch the pedal and the car jumps, and you think "whoa, this car is powerful." Keep pressing and you realize that there isn't a lot left.
    What this underscores is that most of us are reluctant to really press hard on the accelerator - it just feels wrong. We drive around trying to keep something in reserve, so car designers use that tendency to fool us.
  9. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    Here is another use for PWR mode....My newly (driver) licensed daughter has a tendency to accelerate a little slower than I think is prudent, when pulling out onto a road, when there are other cars around. Yeah, she can drive a little slow, and I've been telling her to step on it.... Well, PWR mode solved that problem. I realized the other day selecting PWR might do what I've been trying to get her to do, and it Worked like charm!
  10. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    Well the Prius c presentation said that eco mode limited the ICE throttle plate. So I tend to believe that, so flooring the pedal won't give same performance in eco mode.
  11. qbee42
    3,082
    That information is not entirely correct. The mapping of the plate is modified, but not the overall limit.
    If you think about it for just a minute, it should be completely obvious that a limit would not work in the U.S. All it would take is one accident caused by someone not being able to accelerate fast enough and Toyota would have a class action lawsuit on its hands. Full power must be available in all modes, just as full braking must always be available.
