My 60,000 (58,500) mile service
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ystasino, Jul 12, 2012.
  1. ystasino
    ystasino Active Member
    793
    Tucson, Arizona
    In the first 60 minutes they:
    Changed oil (owner-supplied Mobil 1, 5W-30, $36) for $25
    Adjust all brakes, clean rear brakes, $64
    Recommended against brake fluid change for at least 1-2 services
    Replaced engine filter, $30
    Replaced cabin filter, $40
    After these services they called to say that they were out of PCV valves. I asked them to go buy one and they did. I also authorized the inverter coolant change after I had asked for an inspection.
    In the next 75 minutes they:
    Replaced PCV valve ($12 parts, $107 assembly)
    Inspected and recommended flushing inverter coolant system ($80 labor) with SLLC2 super long life coolant ($20)
    Replaced drive belt ($19 part, $119 labor)
    What surprised me a bit is how quickly they changed the belt, coolant and PCV valve.
    All work was done at Thompson Toyota in Edgewood. The ATF fluid was replaced at 40,000 miles.
    Any comments?
    Thanks!
  2. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    57
    Fullerton CA
    Oil - about right.
    Clean & adjust brakes: Should be $0. Brakes are self adjusting and the rear brakes shouldn't need "cleaning."
    Replacing engine filter: Should be just parts cost - it takes about 2 min.
    Replacing cabin filter: Should be just parts cost - it takes about 2 min.
    PCV valve isn't easy on that - it took me ~1 hour when I did it.
    Flushing inverter - 1 gallon of fluid (~$20) and takes maybe 20 min.
    Drive belt - Go in from the top, ~15 minutes. $119?!?!
  3. daterl
    daterl Junior Member
    At 67,000 I' m ready to replace PCV. Could use some details, looks hard to get to.
  4. brick
    brick Active Member
    1,083
    78
    Upstate NY
    The PCV really isn't that hard. IIRC access is tight but it should be well within reach for anyone who can cope with oil changes and drive belts. If you search around you will find a tutorial or two. I did it and don't recall being traumatized by the experience.
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    Is SLLC2 a new version of SLLC?
  6. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    Rear drum brakes most certainly require periodic cleaning and adjustment. I hose them down with brake cleaner then adjust the star wheel to ensure proper shoe to drum clearance. Self-adjusters do not work well enough to ensure optimal adjustment. 1/2hr labor is not unreasonable.
    Most dealers charge $70-$90 to replace that cabin filter, not that I agree with it. I guess they made up for that labor charge with the drive belt replacement.
  7. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    Anyway,that's how those dealers earn money.;)
