Bluetooth update?
Discussion in 'Gen 2 Prius Audio and Electronics' started by BONGO, Jan 2, 2006.
  1. BONGO
    BONGO New Member
    a coruña, spain
    Just a question... is it possible to set up bluetooth and nav capabilities after buying the car?
    i mean the Toyota original stuff...
    thanx :D
  2. Airgetlam
    Airgetlam Junior Member
    37
    Escondido, CA
    Yes. Can be set up at any point in time, you just go into the settings and tell it when to connect to your device, and what passcode to use. Once you've done that, it's just a matter of syncing.
    Bruce
    2004 Package 9
  3. Oxo
    Oxo New Member
    533
    Oxfordshire, UK
    I don't think this answers what the questioner meant. I'll guess he wanted to know whether it would be possible to add a Nav system and bluetooth compatibility AFTER he has taken delivery of a model without these extras. He might even want to know how much it would cost to do this.
  4. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    Yes, it is possible, but you will end up paying several times more than if you had just gotten the package with it in the first place. It's not worth adding it later, costs way too much.
  5. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    NAV ECU alone cost $4500.... don't think it's worth it, as DocVijay stated above.
  6. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    And although the display itself is the same, the buttons around the display are different, so if you want strictly OEM rather than special buttons to sub for the OEM ones, you need to replace the display assembly, another major expense.
    Then there's lots of wiring. Very labor intensive, and would take planning. Toyota doesn't leave extra wiring if you don't have a package that needs it, if it isn't available as a dealer installable accessory.
