Prius with Two Babies and Gear
Discussion in 'Gen 3 Prius Main Forum' started by geeter, Jul 12, 2012.
  1. geeter
    geeter Member
    208
    Chicago
    That does help. While we would have two rear facing seats with base attachments, this is a similar setup as to what I am thinking about for trips.
  2. geeter
    geeter Member
    208
    Chicago
    Oh man. Do you think if you had a current Jetta Wagon it would have worked? If our family ever grows even more I have no doubt a minivan will be in the cards.
  3. xliderider
    xliderider Senior Member
    8,122
    3,265
    Honolulu, HI
    No, I don't think 3 car seats (2 convertible with wide bases + regular) would fit across the rear seat in anything but the largest vehicles like a Suburban, Tahoe, or Expedition. But if you have one of those, a mini van gets better mpg.
  4. geeter
    geeter Member
    208
    Chicago
    No I just meant now with the two car seats. If we have a third I will have no choice for a minivan. No canyonero however.
  5. xliderider
    8,122
    3,265
    Honolulu, HI
    It depends. Those convertible car seats that go both rear/forward facing with the wide bases sometimes bump into the rear wheel bump that are right next to the rear seat in most cars. Don't know if that is the case with the Jetta Wagon.
    If the 2 seats can be mounted properly in the outside positions, then that's about it, there won't be room for a third person in the middle position.
  6. Aixtrip
    Aixtrip Junior Member
    30
    Boston
    For what is worth, in addition to being longer, the V wagon rear bench moves pretty far back. It still may be tight for your 6'2" legs with one of the rear facing car seats behind you. Give it a try at the dealer!
  7. Brett.
    Brett. Junior Member
    134
    26
    I keep forgetting there is storage room under the carpet / trunk area thanks for reminding me! Seriously, I cram stuff all over and never thought twice about it, haha.
  8. Brett.
    134
    26
    Here is the problem I see with trying to fit two seats in the Prius. It is possible that I have a "large" car seat, but all of them in the store appear to be roughly the same size. The Prius is just that small inside.
    With shoes, I'm 6'-3" and that is where my seat must be for me to drive. Take notice of where that passenger seat must be for the baby's seat to be at the correct angle as to be safe and not allow her head to fall forwards. The passenger sits nearly straight up as well. She was 5'-5" and was not comfortable sitting up front.
  9. markabele
    5,084
    1,782
    Nebraska
    I always thought you were supposed to put the car seat in the middle. That should, in theory, give you more room, right?
  10. xliderider
    8,122
    3,265
    Honolulu, HI
    The baby car seat is too wide, it would hit the driver's seatback in the situation above.
  11. markabele
    5,084
    1,782
    Nebraska
    So pretty much all of you are saying the Prius is too small for a car seat, correct?
  12. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    Wow! Are all car seats that big nowadays? Granted, my "baby" is 24 now, but back in the day infant seats were fairly small. I didn't have a fancy one. It was permanently mounted in the car with no clip-off base unit, so I had to carry a separate baby seat. At that time I drove a Saab 99, which seems like it was about the same interior size as my Prius - or maybe slightly smaller. At first we got a bigger seat, and then realized that even though it was advertised as being safe for infants it was too big and he didn't fit in it properly to be safe. We went back and purchased the smaller seat. The bigger seat worked fine when he was old enough to turn around and face forward.
  13. Brett.
    134
    26
    If my car seat was facing forwards, the passenger could sit in the front just fine, but basically yes having a young family in a Prius requires a short passenger, or no passenger at all. Two seats facing backwards is out of the question, nobody could drive it.
  14. mellowgeorge
    mellowgeorge New Member
    Cleveland, OH
    Those convertible car seats that go from infant to pre-school are really too big when in the rear-facing configuration.
    One solution would be to use an infant car seat in the beginning and then just move up the the next size car seat.
    Yes it means having to purchase multiple car seats but at least the front passenger seat is available for seating.
  15. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    And probably a money saver in being able to buy the Prius now, save gasoline and planet for the kids.
  16. jabecker
    448
    78
    Portland, Oregon
    Yes, that's what I was trying to get at, but you said it much better. Infant seats should fit in a rear-facing configuration with no problem, and are safer for infants anyway because they fit better.
    markabele likes this.
  17. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    I have a rear facing car seat and it is behind the passenger seat. I have to move the seat forward to get the seat in and out, but once it is in, I can move the seat back to a decent position for myself and I am 6'0. This leaves me decent space for everything else.
    Two car seats would be a problem. If you don't use the "base" they don't take up as much room.
    If I had two kids, I would have bought the V instead of the PiP. Lots more room in that.
  18. geeter
    geeter Member
    208
    Chicago
    Thanks for all the pictures.
  19. geeter
    geeter Member
    208
    Chicago
    One of my buddies has a 2010 and has two rear facing seats. He came by and I checked it out. While he is a few inches shorter, he has no trouble fitting both seats and gear. I think it will work. I was seriously going to look at the V and JSW TDI this weekend but I am glad I don't need to.
  20. markabele
    5,084
    1,782
    Nebraska
    I agree. After talking to make few more parents myself the special infant rear facing seats are definitely the way to go.
