Prius: The Crystal Blue Meth of car ownership....
Discussion in 'Gen 2 Prius Main Forum' started by MSAGRO, Jul 16, 2012.
  1. ThinkingPrius
    ThinkingPrius New Member
    how much does a fluid change cost? Maybe I'll do that when I hit 60k miles
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    DIY is about $60 (xmission fluid + funky funnel) but can be had for as low as $~45 depending on where you buy the fluid. I found this link for $10 a quart (plus shipping).
    Toyota ATF WS Automatic Transmission Fluid
    I don't know how much to have someone else do it.
  3. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    Nice looking car you got there!
    MSAGRO likes this.
  4. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Even if a stealer was to charge $200 or $300 for the trans fluid change, imho that is still a lot of cheaper than a new or used tranny. I for one plan to change the fluid at 60K, no matter what the stealer says. It boils down to maintenance, and preventative maintenance is far cheaper than replacement any day of the week.
  5. brick
    brick Active Member
    1,083
    79
    Upstate NY
    I do my fluid every ~45k, and both times it has come out quite dark. The darkness is at least partially attributable to steel fines. I fixed a neodymium magnet to the cap of a bottle of drained fluid and let it sit upside down for a couple of hours. At the end of that there was a black smudge of very fine particles clinging under the magnet. Even if the fluid is chemically intact, I don't want 100k worth of those fines in there at any point in time. It makes me wonder how much gunk is stuck to the strong permanent magnets that are already in there.
    Either way, that's a great deal on the OP's second car. Around here that's not much above trade-in.
  6. bugly64
    bugly64 Junior Member
    66
    Marysville, CA
    Congrats on two nice Prii. I am in Prius nirvana with my 2008 base model, too. I would get another too, but 7 people don't fit.
  7. MSAGRO
    MSAGRO 2010 Prius Five with Advanced Technology Package
    259
    227
    Portland Oregon
    I know, he was asking $13,000 for it ( a good deal anyhow). He must not of been aware of the different packages these cars offer and was selling a pkg 5 at a pkg1
    I at first offered a ridiculous lo-ball price of $9500, after I showed on my iPad other Prii for sale in that price range, i.e: 2004, Base models. Over 100k miles etc... And he looked like I just slapped him. I then thanked him and he drove off..... About 1000 ft, then did a U-turn and said to me "I cannot sell this car for less than $10,500"
    That's when we made the deal
    roflwaffle likes this.
  8. MSAGRO
    259
    227
    Portland Oregon
    Toyota dealer charge for CVT fluid change is about $160
    dorunron likes this.
  9. dorunron
    3,318
    1,105
    Houston, TX
    Sounds about right to me, when you figure the time spent along with the cost of the fluid. A good tech might be able to do the job in an hour, but I bet most of them will dilly dally around and spend two hours on the job.
    I will be finding out soon what the stealer actually quotes on this as I am at 58K on the clock and will be changing it just shy of 60K. Next service due at 59.8 K or something like that...
    I have no problem paying the stealer to do this since I am handicapped, and do not have tools, lift, and other items it would take to do this job properly. As long as I physically see the old fluid being dropped out and the new fluid being replaced along with the tech. showing me that the transaxle is full before replacing the fill plug, I will have no problems or doubts of letting the stealer do this. Most stealers will allow someone to observe things if they ask nicely. Yes, they say things about insurance and what have you, but for the most part they will work with the customer who spends their hard earned money. If a stealer is trying to hide things from you, or they won't work with you, go somewhere else.
    Getting back to the original topic, I too have to agree that OP got a heck of a deal on his #2 Prius!
  10. Patrick Wong
    18,210
    6,510
    Well, this is a really simple job. My guess is that the elapsed time is more like 15 min. Remove the fill plug and drain plug and let the old fluid drain out which happens very quickly since the ATF viscosity is very thin. Wipe off the magnet on the tip of the drain plug. Then replace the drain plug with a new washer, add the new fluid and then replace the fill plug with a new washer.
    The ATF WS sells for around $9 per quart and 4 quarts are needed, so the fluid alone will be around $36+. Add $2-3 for the two washers, and the rest of the quote will be labor.
    dogfriend and dorunron like this.
  11. MSAGRO
    259
    227
    Portland Oregon
    . That was the price I paid for the Gen I that I got. Not sure on the labor time because the service manager looked up my VIN and said it needed 4hrs time for that recall on the steering nut problem.
  12. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Whoa, $1 a washer?
    I'm in the wrong business. How about I start selling special "Prius washers" for 50c ea? ;)
  13. dorunron
    3,318
    1,105
    Houston, TX
    Tejas Toyota in Humble, TX just quoted me $134.36 total price for the CVT fluid change. They also said the usual stuff about long life fluid and such. The service writer at first quoted me a ridiculous figure ($300) and stated it took about nine quarts of fluid to flush the system. I stated that I believe it only takes four quarts for the change and that the transaxle did not need to be flushed, but simply drained and refilled. At that point, the service writer conferred with the head honcho in service. He stated it takes about 6 quarts to change it out properly since their practice is to fill it partially, then drain it after the initial drain to help flush the particles out. He stated that the Gen 2 09 year model did not require flushing, but draining only. He also said the same thing about the long life of the fluid, but had no qualms in doing the work.
    $134.36 is still a lot cheaper in my book than a new or used transaxle. What did the commerical say? "Pay me now, or pay me later".
    I still plan to have the work done at the next service interval.
  14. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    not a buck a washer....its a package labeled "fluid change kit" for $2.79 plus tax of course
  15. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    owners manual on my '04 said trans fluid change at 100k, 60k under "extreme conditions" i think is how they worded it. i did mine at 100k and it was nasty! i'd urge everyone to do it closer to 60k. easy job, just drain and fill. 4qts WS and a funnel w/ a hose on it.
  16. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    I hate you! ;)
    MSAGRO likes this.
