Features You Discovered After Buying Your Prius
Discussion in 'Gen 3 Prius Main Forum' started by Jar, Jul 10, 2012.
  1. Rigbyfab4
    Rigbyfab4 Junior Member
    Maine, USA
    Can anyone explain more about the DRLs? How do you select them to be on or off? Are they standard on all trim levels?
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I think they are new for 2012. On a 2010 you may turn on the headlights, then just never turn them off. (Actually every oil change, my Toyota tech turns them off, and I drive feet before I notice)
  3. Rigbyfab4
    Maine, USA
    Thanks for the tip - I think that's how I'll roll!
  4. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I just discovered that the passenger-side rear quarter-light of our 2015 Prius Four (bought about three years ago) has a heating element; none on the corresponding driver-side quarter-light.
  5. ChapmanF
    18,587
    By quarter-light, I take it you mean the fixed glass in the passenger quarter panel?
    That's no heating element, it's an FM diversity antenna. New in the 2012 mid-Gen-3 refresh.
  6. NewHybridOwner
    607
    283
    W. Michigan
    Seems an odd configuration for an antenna, but I think you must be right: I turned on the rear defroster, and the rear glass got warm but not that quarter-light.
  7. AzusaPrius
    AzusaPrius Senior Member
    2,244
    931
  8. ChapmanF
    18,587
    If you look at the pattern closely, you'll see it has dead ends.
    By contrast, you'll see the heating trace pattern on the rear glass makes a complete DC circuit. :)
    At one point I was thinking of modding my 2010 with a later radio, and salvaged the diversity antenna amplifier and cable out of a later-model wreck.
  9. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    I've been learning of normal car maintenance expenses folks with Toyota Hybrids do not have....no serpentine belt to replace because both the water pump and A/C are electric. No transmission filter to replace because the transmissions are even easier than an oil change, just drain and refill. And, best of all, our brake pads don't need replacing every 30,000-45,000 miles because we have two braking systems...the old hydraulic brakes and the regenerative brakes...so our brake pads can last 100,000-150,000 miles. (That electric motor buzzing when you open the car door is actually that regenerative brake system priming itself to be ready for use while driving.) I didn't know what that buzzing was for years after we got the 17 Prius.
  10. Colorado Boo
    307
    202
    2021 Prius
    LE AWD-e
  11. Mendel Leisk
    41,948
    I've mentioned these elsewhere, and a little embarrassing, but funny.
    1. And ok, I "knew" this on SOME level, but it hadn't sunk in: first time I backed out of our garage, looked back, and totally realized: "wait a sec, this is a hatchback". Yeah, I know.
    2. Had the car for maybe 3 years before I figured out there was a secondary glove box, up above on the dash.
    3. Took me a week or two to sort out how the touch to unlock worked, lol.
  12. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    but when we call them about egr circuit leading to head gasket issue, they say “we never heard of such issue.”
