Prius Smell Removal
Discussion in 'Gen 2 Prius Main Forum' started by mike1990, May 23, 2011.
  1. kenmce
    kenmce High Voltage Member
    1,551
    523
    NY
    There is no such thing as a normal battery smell. The batteries should have no smell whatsoever.
  2. ArtsNfartsncrafts
    ArtsNfartsncrafts New Member
    Knoxville
    This is an interesting thread, because the first thing my wife said when we test drove ours was, "It kind of smells like a deer, or something."
    Weird!
    Something that has helped mine significantly: I got a few of those yankee candle vent clips, and those have helped quite a bit. But what REALLY has helped (and no, they're not paying me to say this), was installing a leather center console cover from PriusHoods on Ebay. That's genuine leather they're using, and the strong smell permeates the vehicle very nicely.
    Almost has that "new luxury car" smell!
  3. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    Awww, isn't that just the cutest thing? Our latest spambot learned how to do a search! (Look at its other posts, folks).
  4. cozmisu
    cozmisu Junior Member
    24
    Romania
    Someone it seems that found the cause of this smell:
    "I have a 2006 Prius and have been fighting this smell for a couple years.
    Here is what is causing the nasty smell.
    Under your back seat are the batteries.
    Try smelling in your trunk by the spare tire.
    These are enclosed in a steel box and vented to the rear passenger side of the car's wheel well. On top of thes batteries are (2) plastic tube vents that connect each of the battery cells together. Part # 28876-21020 you need (2) at $80.95 ea. You can not see these vents without taking the rear seats out and taking the steel battery housing apart. Real pain.
    Even though the batteries are under warranty Toyota says these are not covered?
    These tubes get sticky and smelly as they degrade. I took them out and 5 days latter the smell is greatly reduced. It takes time because there is some sticky material left on the batteries and this need to evaporate.
    Toyota took 3 days to get the 2 parts in and when I went to install them I found one of the new vents was sticky and smelly. I am waiting for a replacement. They must have a production problem on these parts.
    We need to fight Toyota on this repair. This should be covered under warranty. Who knows what chemical we have been breathing. They are playing dumb. There are postings about this on internet so this is not an unusual thing.
    I think you are better off having the dealer do this work rather than doing it your self.
    Good Luck"
  5. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    211
    San Diego, California
    Beano works for me
  6. Navi05
    Navi05 New Member
    I have the exact problem, and no plastic part this small should cost $80.95 ea.
    Possible fixes:
    1. Seal it with brush on acryclic/silicone sealant and hope it keeps it from degrading.
    2. Make a replacement part out of silicone instead.
    3. Use stainless steel to replace the part.
  7. tumh
    tumh Junior Member
    I had a truck with that kind of problem. Big truck. Lots of seats, carpets, headliner, door panels. Took it to detail shopthat clained to deal with odors. They dealt with mine very nicely. Shampoo and scrub for all upholstered surfaces. Air cleaner through heater/AC ducts. New filters. Then it sat two or three days with their electronic air cleaner running in it. Very good results. Cost less than $200 I believe. Good luck with yours.
  8. wzup
    wzup New Member
    We read elsewhere that the ducts on the electric battery were the cause of the smell. Prius battery exploration We ordered these parts from Toyota Parts East (I think) they were cheaper than through the dealer. We had them installed by a dealer, and the smell is now gone. Only issue is, I had the dealer save the parts for me so I could confirm the problem. These ducts, about 16" long, two of them, were very sticky and smelly. The exact smell that was in our Prius. I called Toyota US to ask for reimbursement, since this is definitely a Toyota problem. They refused, are denying the problem exists. So, we are out $300+ and had to put up with dead animal-like smell for three years until we read online how to fix it.
    PriusGuy32 likes this.
  9. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Thanks for TTT this thread - my 07 has a smell that a lot of people comment on. My bf says it smells like "something has died inside"... I dont smell anything though!
    Im going to inspect these battery vent lines now! I bet its my problem.
  10. Beverly Gunter
    Beverly Gunter New Member
    Greenville, SC
  11. bisco
    52,386
    it's often the battery vent tubes.
  12. dolj
    dolj Senior Member
    8,555
    4,346
    Wellington, New Zealand
  13. Mendel Leisk
    41,898
    Well almost: you might be better off to just procure some vinyl tubes and replicate the original vent tube function. Cheaper, and Toyota's replacement might start smelling again.
