Center console storage LED lighting
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AZGeek, Jul 22, 2012.
  1. AZGeek
    AZGeek Semi-informed Member
    627
    144
    63
    Arizona
    I tapped into the driver front foot-well power and installed a blue LED to illuminate underneath the center console. I used a NEO5-B twist lock instrument cluster LED from superbrightLEDs.com, the lens housing of which fit perfectly into the hole that exists in the bottom of the shifter housing. I did shave off one side of the twist lock base to fit flush with the plastic guide that holds the two halves of the instrument housing together. I ran the wiring through the dash and over to the foot-well connector on the driver's side.
    I am pretty happy with the result. :) The lighting reflects more off the tray insert I have, so it appears brighter in the pic, although it is the same brightness as the foot-wells. Same color, too, plus they they all dim out when the timer goes out. I drove around tonight and the lighting is not distracting --- more light is coming out from the NAV display than anything else. I'm not so happy with the fact that I dinged the armrest and scratched the illuminated door sill because I wasn't paying attention to what I was doing while working on the car. :(
    I also swapped out the glove box LED with the same NEO5-B blue LED. (I know it's only a matter of time before I go after the center console, A/C display, etc., lights and swap them out with blue as well. :rolleyes:)
    The last pic also shows the rear foot-well lighting I installed using the same LEDs and tapping into the foot-well connectors up front.
    Madriz10, F8L, genetiix and 1 other person like this.
  2. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    Looks cool! Was thinking of buyin 2 Lexus LEDs for the footwells that are white and wiring them into the front passenger footwell light and putting under front seats to light up the rear footwells like you. Where did you attach them and what's the best route for wiring from passenger footwell?
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Looks real good dude. I really like the rear seats light.idea.
    AZGeek likes this.
  4. AZGeek
    627
    144
    63
    Arizona
    I attached them right at the edge SofTex seat material. There actually is a small cutout of the SofTex at the center line of the seat, and the LED fit nicely in that slot. I used a small binder clip to attach the LED to the SofTex material --- clipped right on the edge and works well.
    Routing the wiring was just as easy. You can tuck the wiring up under the lower edge of the center console trim, right where it meets the carpeting. Once you run that to under the dash then you can jog over to the foot-well lighting connector. I exited the console about half way under the seat, to allow for enough play for adjusting the seat all the way forward & backward. Make sure you move the seat back all the way before measuring / cutting the wiring to length. I left about an inch of additional length so the wiring isn't stressed when the seat moves all the way back.
    Let me know if you'd like me to take pics of what I just described.
  5. SuperGLS
    SuperGLS Member
    200
    52
    Washington DC
    Yeah, that looks pretty good. I'd do white myself, but the blue also looks good.
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Looks AZGeek......I really like the lower center console idea. More modding here I come
  7. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    Photo's would be great!!! Very tempted!!!
  8. AZGeek
    627
    144
    63
    Arizona
    Here are some pics of what I did for wiring for the rear foot-wells.
  9. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    Looks ideal, will copy those! Thanks!!!
  10. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    I have blue LED dome lights, but I'm following your lead here after seeing this.
    WAY TO GO>
    AZGeek likes this.
  11. Tideland Prius
    16,596
    Did you make the wiring yourself?
  12. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    i'm still unsure, how you set up the leds for the lower console tray
    thanks !!!
  13. jmrmotorhead
    jmrmotorhead Junior Member
    85
    44
    New Hampshire
    Looks sweet! I'm planning this for somtime soon! Have a link to the led's you used?
    matt
  14. AZGeek
    627
    144
    63
    Arizona
    Sorry for not responding sooner. Yes, I did the wiring myself. I found a jacketed two wire cable which made for easy routing of the wiring and a much cleaner installation.
    iPad ?
  15. AZGeek
    627
    144
    63
    Arizona
    I will try to take some more pics to better explain the wiring. It is a very simple set-up, with the most difficult part being trying to fish the wire from the driver's side footwell through the lower dash cluster and over to the shifter housing. Not anywhere near as bad as the flasher relay swap out or the noise maker disconnect.
    iPad ?
  16. AZGeek
    627
    144
    63
    Arizona
  17. ucsmfu
    1,498
    420
    canada
    that would be awesome :)
    thanks !!!
  18. ucsmfu
    1,498
    420
    canada
    btw, when are we soldering to make all our internal instruments blue led ??
  19. ucsmfu
    1,498
    420
    canada
    how do we remove the front dash trims ?
    and also, how do we remove the leds ?
    thanks
  20. ockevin
    ockevin Active Member
    493
    148
    Orange County
