Front camera...?????
Discussion in 'Prius v Main Forum' started by CLUBGUY, Jul 22, 2012.
  1. CLUBGUY
    CLUBGUY Member
    293
    Cincinnati
    Any thoughts/experience with a "front" mounted camera...in my case it's just a matter of time before I hit something with the front while parking....
  2. Ron K
    Ron K Junior Member
    61
    Yorba Linda, California
    The lexus H250 had one of these. I test drove one. It would come on when going under 3 or 5 miles per hour. Two great uses, parking of course and pulling out of a parking space after backing in. Just like a rear mounted camera, because of it's field of view being about 160 degrees, it could "look around the corner". I thought it was great.
  3. GerryL
    GerryL Master Model Railroader
    170
    Minneapolis, MN
    Would love one. I keep pulling my V into the garage and thinking I'm about hitting the lawn tractor at the back of the garage. I get out and I'm still 2 feet away.
  4. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    When I had a big old truck many years ago, I tied a washer to a string and hung it from a garage rafter so it would tap the windsheild when I had pulled in enough!
  5. GerryL
    170
    Minneapolis, MN
    I've actually heard of doing that with a tennis ball. And it would work. Except that then you've got this tennis ball hanging from the ceiling to avoid whenever you're working in the garage.
  6. benagi
    benagi Active Member
    525
    280
    Utah
    I just put a strip of wood on the floor where I park and drive up to it and when the wheel hits it I know I am in far enough to close the garage door.
  7. OWG
    OWG Junior Member
    86
    Barrie, Canada
