Rear driver's side window - no defroster strips?
Discussion in 'Gen 3 Prius Main Forum' started by 2Llamas, Jul 23, 2012.
  1. 2Llamas
    2Llamas New Member
    Something my husband noticed on my new Prius - there aren't any defroster strips on the tiny window on the drivers side.
    Is this normal or should I call the dealer?
    Thanks,
  2. Brett.
    Brett. Junior Member
    134
    26
    I have never seen a rear side glass with a defroster built in, only the rear glass itself. The mirrors may have defrost capability.
  3. nicholfd
    nicholfd Junior Member
    Indiana
    On the 2012, the small passenger rear, triangular window has defroster strips. The driver side does not.
  4. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    Those are for the radio I thought, not defroster strips.
  5. mjones12
    mjones12 Member
    115
    26
    North Carolina
    Mine is the same way, which seemed curious to me, too. I'm guessing that the driver could look back and see out the passengter side window but would not have a good line of sight out the side back window on his own side. Maybe that was the thinking in putting the strips only on one side.
  6. Brett.
    134
    26
    Paradox is correct that is an in-glass AM/FM antenna
  7. 2Llamas
    2Llamas New Member
    Ah, the radio makes sense. Thank you!
  8. mjones12
    mjones12 Member
    115
    26
    North Carolina
    It does make sense. I thought it was defroster wires, too. Now I won't be taking it to the dealer this fall when the frost won't melt off that little window. I assume the antenna on top is for the Nav and, possibly, XM.
  9. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    The base is for xm, the part sticking up is for fm and am, the one in the glass is a second antenna to improve reception.
  10. mjones12
    mjones12 Member
    115
    26
    North Carolina
    Excellent. Thanks for the info.
