calculated vs. computer MPG - Please post your results
Discussion in 'Gen 3 Prius Fuel Economy' started by F8L, Jul 10, 2009.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Trip A : 5,111.5 Miles
    Average Speed: 40 MPH
    Indicated MPG: 54.6
    Calculated MPG: 52.289
    Gal's used: 97.753
    Gas Type: Regular unleaded various brands Costco etc. with 10% Ethanol
  2. sunnyd
    sunnyd Junior Member
    So Cal
    Just filled up and the computer indicated 57.7 MPG when real MPG was 54 MPG. Off by about 6.5%.
  3. remco
    remco Junior Member
    Warwick, Rhode Island
  4. remco
    remco Junior Member
    GPS will tell you! I have a 2010 III with 40K miles. I noticed the mgp always about 3 % lower than the calculations at fillup. Then I noticed my gps shows me going 57mph and the prius shows 60mph on the highway. I imagine you'd have to check other gps' to see if the prius does really read the mph high. Obviously if it does...there's your error cause. Yes, I have the stock tires. What do you get on a gps for compared speed?
  5. F8L
    19,011
    4,081
    Grass Valley, CA.
    The car computer reads correctly despite the speedo being off by 2mph on average. Others have checked odometer accuracy via highway mile markers and the odo appears accurate. :)
  6. F8L
    19,011
    4,081
    Grass Valley, CA.
    Miles: 702.5
    Gallons Pumped: 10.171
    MFD = 71.7mpg
    Calculated = 69.1
    MFD vs. Calculated = -2.6
    % Error = 3.8%
    Avg Speed: 37mph
    Price: $3.599
  7. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Trip A / several fillups
    Miles: 6,136.1
    Indicated MPG: 55.3
    Calculated MPG: 52.863
    Error: 2.437 mpg
    Gals' used: 116.074
    Avg. speed indicated: 40 MPH
    Gas: regular unleaded with 10 % Ethanol (mostly Costco brand)
    Tires: 195x65x15 Michelin Energy Saver AS tires with 44 PSI
    max sidewall pressure in all four tires.
    In theory and I believe in fact, the more miles you have and fillups
    the more accurate you will be on your figures when comparing
    indicated MPG's with calculated MPG's.
  8. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Trip A (several fillups) without resetting
    Miles: 6417.7
    Indicated MPG: 55.5
    Calculated MPG: 53.0792
    Difference: 2.421
  9. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Last tank, filled up 07/28
    600.2 miles
    10.38 gallons
    Dash reading 61.2 mpg/manual calc 57.8 mpg = 5.5% error
    Average speed 30 mph
    Constant AC use 75/76 F one to two bar manual setting.
  10. alleyooptroop
    alleyooptroop New Member
    49
    Hopefully you guys can shed some light on what I'm experiencing. Just bought a package 5 about a month ago. Right now on my current tank the car is showing only 43 mpg! I used trip A to see this info. On trip B (which hasn't been reset since I bought the car) I'm getting 45 mpg. My trips are mostly round trip to work which is about 16 miles. That round trip is about 30% stop and go residential and 70% longer stretches of city driving. I'm almost always in Eco mode and I'm trying my best to apply all the driving techniques I've read about here. There are only 650 total miles on the car so I'm wondering if it's a break in thing? Would appreciate any light being shed on my poor (comparatively) mileage.
  11. F8L
    19,011
    4,081
    Grass Valley, CA.
    This really isn't the place for this question but yes, it's a break in thing as well a a 17" wheel thing and a new-to-a-GenIII thing. :) all of these combined along with semi-short trips can ding mpg. With decently long trips and some effort you may be able to get into the 50s but a lot of folks average mid-high 40s with 17" wheels unless they have a killer commute, drive slow, hypermile or use 100% gasoline. I would expect your mpg to go up once you figure out the nuances of this car and the tires/car breaks in.
  12. alleyooptroop
    49
    Oops. My apologies for posting in the incorrect thread. Should I start a new thread?
  13. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
  14. markabele
    5,084
    1,782
    Nebraska
    Miles: 700.2
    Gallons Pumped: 10.141
    MFD = 72.4 mpg
    Calculated = 69.0
    MFD vs. Calculated = -3.4
    % Error = 4.63%
    Avg Speed: 23 mph
    Price: $3.73
    F8L likes this.
  15. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    523.4 miles
    9.46 gallons
    58.9 mpg dash reading = 6.1% error
    55.3 mpg calculated
    29 Avg Speed
    3.29 a gallon
    Constant AC use
    Stock 15 inch tires - 42/40
  16. F8L
    19,011
    4,081
    Grass Valley, CA.
    Mark and Kalome, those are nice tanks. Congrats!
  17. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Why thank you, but not as good as your numbers.
    I just posted a thread. I would be interested to know how you have yours setup on your Gen III.
    Mounting your scangauge | PriusChat
  18. markabele
    5,084
    1,782
    Nebraska
    Thanks man!
    Off topic, but has there always been this many crazy anti-good-gas-mileage people on this forum? Some of those other threads are nuts.
  19. F8L
    19,011
    4,081
    Grass Valley, CA.
    Everyone's situation is unique so I try to take that into consideration when judging someone's mpg numbers. I know what you are dealing with temperature wise and I think you are doing well so I have to say something. My average numbers are only 64-67mpg indicated because of my uphill commute and higher speeds. If I moved back to my old house my numbers would drop quite a bit. :)
  20. F8L
    19,011
    4,081
    Grass Valley, CA.
    Your ability to pop off 70mpg+ tanks left and right makes me jealous! :)
    The sudden influx of anti-hypermilers is nothing new. When a new model of Prius comes out we see a lot of new members who traded in sports cars for a Prius. They continue to carry their old justifications for speeding and their anger for those who would rather driver slower. I find it amusing that just because they came over from an Acura TL or a BMW We are supposed to be impressed or that maybe they are the better drivers or more courteous because they speed. *rolls eyes*
