XM Radio in 2012 Prius 2?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by dvdirv, Jul 7, 2012.
  1. dvdirv
    dvdirv Member
    144
    Atlanta, GA
    How easy is it to install XM Satellite Radio in a 2012 Prius 2?
    My dealer said it was extremely difficult to retro-fit and instead suggested getting a Prius 3 with XM already installed.
  2. Hank101
    Hank101 Member
    108
    SC
  3. LARRYG36
    LARRYG36 Member
    123
    45
    Southern Nevada
    Its supper easy, the panels just pop out, running the antenna wire to the back was fast and easy too.[​IMG]
    I also wired in the Radar Detector.
  4. hadone
    hadone Junior Member
    Iowa
    Where did you get mounting bracket? Where did you route the wires. This look very professional
  5. tach18k
    tach18k Member
    406
    SoCal Beach Area
    I thik I saw somewhere that for about $350 you can get a converter that will interface with the 2012 touch screen.
  6. LARRYG36
    LARRYG36 Member
    123
    45
    Southern Nevada
    We didnt want to activate the XM in the factory radio because we use our portable xm unit for our house/2 cars/walking/biking. Like i said, install was a snap, the dash justs snaps together and apart, no screws. I spliced into a hot wire behind the lower glove box and put in a 2 plug cigaret lighter unit. One for the xm step down plug and the other for the radar detector. Wife and I hate looking at wires. So nothing is exposed, and none of the factory power outlets are used. That cool xm mount i found at Proclipusa.com .
