WMF exploit workaround
Discussion in 'Fred's House of Pancakes' started by JackDodge, Jan 4, 2006.
  1. JackDodge
    JackDodge Gold Member
    2,366
    Bloomfield Hills, MI
    For those unfortunate souls who have a windows computer, you probably know that hackers have found an exploit that utilizes the Windows Picture and Fax Viewer to get in to your computer. Known as the Windows Meta File exploit, it can infect your computer through images. This is a highly dangerous vulnerability that has everyone very worried. Microsoft has said that it will come out with the patch to close this vulnerability on Tuesday but there is a workaround that they've recommended to keep malicious code from infecting your computer in the meantime. Basically, it disables the Windows Picture and Fax Viewer but can be easily reenabled so you're not doing any damage to your OS.
    Click Start then Run then paste the following line in to the Open box and click OK
    regsvr32 -u %windir%\system32\shimgvw.dll
    You should get a popup box that says "DllUnregisterServer in C:\WINNT\system32\shimgvw.dll succeeded."
    To undo, repeat the procedure but use the following line instead:
    regsvr32 %windir%\system32\shimgvw.dll
    For more information on this workaround, follow the link:
    http://www.microsoft.com/technet/security/...ory/912840.mspx
  2. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Done.
    What did I just do?
  3. aka007ii
    aka007ii New Member
    482
    Santa Clarita, CA
    You've just been social engineered. :lol:
  4. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    You've just unregistered the "Windows Image & Fax Viewer" application from being automatically launched whenever "you" want to view an image file format that it would normally handle, the problematic WMF files included.
    However, if System File Protection is still enabled, Windows may re-register that file at any time. Additionally, other software may still use the library as needed. What you've done is a stopgap measure that helps avoid accidental infection, but doesn't guarantee against it.
    This security hole has been around since Windows 3.x, but it was only in Windows XP and 2003 Server that the WMF file format had a default association -- making these versions of Windows more vulnerable than the older versions... but that's not to say that the old versions are safe from the exploit, either.
    It's widely assumed that Microsoft will not be releasing fixes for this exploit to any operating systems earlier than Windows 2000 -- meaning those people still running 95, 98, or ME will be seriously open to attack unless they finally bite the bullet and upgrade Windows (or switch to another operating system, like Linux or MacOS).
    Again, the "fix" above is only a stopgap measure and is not a guarantee that you won't be infected if you receive a malicious Windows Metafile image (WMF). There's a 3rd-party patch, which is a little more serious, and actually *disables* the security hole. You can download it HERE, but you do so at your own risk -- this is NOT a Microsoft sanctioned fix. Microsoft's solution won't be distributed until Jan. 10, 2006.
    For more information, search Google for "WMF exploit" or read various Blog entries like this one.
  5. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    WMF: Weapons of Mass Fenestration
  6. JackDodge
    2,366
    Of course, you can run the "stopgap measure" as often as you want.
    Well, considering that Microsoft doesn't support any OS previous to 2000 anyway, people with 3.1, NT, 95, 98, 98SE and the dreaded ME have been on their own for some time so this patch doesn't include them either. That's no surprise. To answer the question before it's asked, yes, I actually do know a couple of people who are still running 3.1. :p As a matter of fact, some are still using DOS 7
  7. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Allow me to explain...my dictionary says fenestration is "the arrangement of windows in a building" Still not funny? Oh well, I try... :)
  8. LaughingMan
    LaughingMan Active Member
    1,386
    Marlborough, MA
    Uhm. That joke was kind of Dennis Millery....
  9. jeneric
    jeneric New Member
    442
    Redmond, WA
