Owners Manual for PIP is out
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PRPrius, Feb 12, 2012.
  1. CharlesH
    2,796
    1,163
    Roseville, CA
    For one, in Canada, the headlights are used as the daylight running lights, but the in U.S., they are separate.
  2. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Do you have the Auto on the light switch?
    Mine doesn't have Auto.
    It has DRL position seperate from the Headlights position, but the DRLs are on with the Headlights.
  3. CharlesH
    2,796
    1,163
    Roseville, CA
    Note that I am not in Canada. There was a thread somewhere about how DRL are required in countries at high latitudes, and the subject of how they are installed came up.
  4. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
  5. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    Bad link - the correct one is http://priuschat.com/forums/toyota-prius-plug-in/103349-owners-manual-pip-out.html#post1468408 .
    I had already posted a version with fixed page numbers and bookmarks (see this post above), but yours are better. I'll edit my post to point to yours.
    Anyone want to fix the clickable page references? Only the ones pointing within the original manual sections work.
  6. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    I can't access the owners manual ryogajyc posted to Google. It wants me to sign up for something, which I'm not going to do.
    Does anyone have the whole PDF owners manual in one file that I could access from elsewhere? Or can someone email it to me?
  7. ryogajyc
    985
    165
    Reseda, CA
    The manuals are public and do not require a signing in. If you see a sign-in screen, look for a sign out link, then try the manual link again. I believe it is remembering a previous sign-in (for convenience) and then prompting for the password for security.
  8. 13Plug
    581
    105
    2013 Prius Plug-in
    I cleared all google.com cookies and tried the link again and then it worked. Stupid but OK, it worked, thanks.
  9. hb06
    hb06 Member
    550
    Huntington Beach, CA
    Here is a good video on using the PIP Tire Repair Kit and 12V Tire Inflator included. Seems the included 12V Tire Inflator (which label says was made for use with the PIP) could be used without the sealant to temporarily inflate the tire more.
    Video from carfave.com/2012-prius-plug-in-tire-repair-system/
    2012 Prius Plug-in: Tire Repair System | Cars trucks and SUV Buying and repair tips and video
  10. bisco
    51,835
    wow, what a pain in the pittsnogle! thanks for the vid, i need to buy a spare.
