New Prius will not start
Discussion in 'Gen 3 Prius Technical Discussion' started by VicVicVic, Jul 27, 2012.
  1. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    I would leave the car on for an hour so the HV battery can continue charging the 12 volt.
  2. VicVicVic
    VicVicVic Junior Member
    51
    San Francisco, CA, USA
    By that, do you mean drive around for an hour, or actually just power on the car, leave it there for an hour, and then turn it off?
    There are some issues with the insurance company with adding this car and the driver, so I cannot really drive it around for the time being.
    Thanks,
    Vic
  3. Erikon
    819
    105
    Rochester, NY
    Just leave it on and running. The engine charges the HV battery which in turn charges the 12 volt.
  4. Erikon
    819
    105
    Rochester, NY
    Start it like your going to drive it, foot on the brake, push the power button!
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Yep. Doesn't matter if the Prius is moving or not. It has no effect on how quickly/slowly the 12 volt charges. Just leave it in READY mode (READY light ON).
  6. guicide
    guicide Junior Member
    New Hampshire
    My 2012 turns on the interior lights as I approach.
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I would press the dealer to replace the 12v battery. Tell them, once dead the battery will likely fail again. You shouldn't have to worry about that with a brand new car.
  8. tach18k
    tach18k Member
    406
    SoCal Beach Area
    When you go and get your 1000, 5000 mile checkup make sure they test and charge the battery. Also my 2012, the interior lights do come on when I approach the car. Keep calling toyota care when ever it breaks down, do that first.
  9. macman408
    1,179
    368
    What's the date of manufacture on your car? Perhaps it was sitting on the dealer's lot for too long, and the battery died because they never had it on long enough to charge the battery? Especially if you can give them that scenario, you might be able to convince them that the 12V battery needs to be replaced.
    Otherwise, if I were a dealer, I probably wouldn't replace a 12V battery after needing one jump start, unless I was feeling particularly generous. From their point of view, it's just not the most likely problem (more likely would be the customer accidentally leaving a light on), and normal use might fix it anyway.
    In any case, if you can't get a free replacement, I wouldn't worry too much about it. I killed mine absolutely stone dead about 2 months after getting the car; it's been over 2 years since then, and I haven't had a single problem. This weekend, my wife even left the interior lights on (she doesn't know how - she doesn't remember turning them on, and it was mid-day when she was driving so she had no reason to use them) for about 5 or 6 hours until our neighbor knocked to let us know. The car still started just fine, though the battery was obviously low (the lights were dim and brake pump ran slowly until I went to Ready mode).
  10. WE0H
    WE0H Senior Member
    3,247
    528
    I wonder if that is a programmable feature? Mine doesn't turn on the interior lights as I approach it. Many rental Prii have turned on the interior lights when I got close to the drivers door.
    Mike
  11. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    Both my 2005 and my 2012 turn on the interior lights when I approach the drivers door. It's a nice parlor trick to show my friends.
  12. WE0H
    WE0H Senior Member
    3,247
    528
    Wonder what the Xgauge codes are to toggle that option?
    Mike
  13. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    On the '10 and '11s, it was a dealer customization via Techstream. See Things that can be customized | PriusChat. Some of those can now be set on the '12s via LCD.
  14. jabecker
    448
    78
    Portland, Oregon
    I glanced at the Owner's Manual customization list, but I didn't see it there.
    WE0H likes this.
  15. jim256
    jim256 Member
    317
    69
    Eastern NC
    On the 2010, the car has to be locked for the lights to activate on approach. Was it locked?
    jabecker likes this.
  16. WE0H
    WE0H Senior Member
    3,247
    528
    Nope, I'll try the locked approach today. I always leave my car unlocked in my garage where it sits mostly ;)
    Mike
  17. jabecker
    448
    78
    Portland, Oregon
    Oh, good catch! My car is always locked, and the 2005 was also. Didn't even think of that.
  18. macman408
    1,179
    368
    It also depends how good your ninja-fu is. I usually sneak up on my car fast enough that the lights don't start coming on until right about when I grab the handle - to an outside observer, it would look like the lights came on because I unlocked it, not just because I was nearby.
  19. WE0H
    WE0H Senior Member
    3,247
    528
    Just tested mine today and the lights do come on when I snuck up on my car with locked doors.
    Mike [​IMG]
  20. fuzzy1
    10,603
    I erred by not waiting long enough in my earlier test.
    Immediately after locking the car, the interior lights go out and don't respond to the key's proximity. Wait a bit and retest, and the lights do come on.
