My 2012 Blizzard White Pearl Prius w/ FRS Wheels + H&R Springs
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Jay J, Jul 28, 2012.
  1. F8L
    19,011
    4,083
    Grass Valley, CA.
    :p Just giving you a hard time.
  2. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    Amazing car, take good care of it! It looks absolutely stellar.
  3. Jill E
    Jill E Member
    60
    40
    San Diego
    I totally dig it. Did you keep the same lugs?
    And which brand of spacers did you buy?
    It's pretty tempting to buy seeing the ft86 forums selling me off like crazy. And I have my Prius five rims as well and wanting to change the look and I suppose the tires will switch right over!
  4. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    Just generic white knight 3mm spacers :) ..I'm using the OEM lugs but I know you aren't supposed to...I ordered new ones waiting for them to come in.
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    I see that the FRS wheels have a +48mm offset. This would be beneficial from a fuel efficiency standpoint as it keeps the wheels tucked into the wheel well more and out of the airstream. The OE 17" wheels on the Five are a +50mm offset. The further a wheel sticks out of the wheel well the less aerodynamic the car becomes thus lowering fuel efficiency even further than the addition of a 17" tire alone will.
    Just something to think about when adding spacers for the more flush look.
  6. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    You need at least a 3mm spacer to clear the calipers (front/rear)...So then the ET offset would be 45mm.
    F8L likes this.
  7. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    I'd like to get Bilstein but Bilstein UK have to do a special import from USA, so end up costing an extra $150, H&R are my next best option.
    What kind of drop did you get and what is the ride like compared to stock?
  8. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    1.3" front and 1.1" rear.
  9. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Is this something that 1 of us can get for u & ship it to u instead of have.g to pay an import fee?
  10. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    That would be amazing but the shipping alone from USA to the UK would be rather heigh on its own, putting them a lot more expensive than the H&R's, that are readily available to me over here.
    Thanks for the help however!
  11. BigPete
    BigPete Member
    149
    56
    Plymouth, UK
    Cool.
    What is the ride like, harsher than stock, less roll?
  12. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    Less roll and it rides like OEM
  13. 227beegee
    227beegee New Member
    car looks great!
    where did you get the Toyota logo center caps?
  14. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
  15. The Critic
    The Critic Resident Critic
    3,193
    2,328
    CA
    Looks nice.
  16. The Critic
    3,193
    2,328
    CA
    Question: you mention spacers, due to the +47 offset. But Prius plus wheels have a +43 offset and do not require spacers. So, was there really a clearance issue?
    iPhone ?
  17. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    The FRS wheels have a low disk backpad backpad therefore hit the calipers (both front and rear). Since the hubs on the FRS stick out to give it stability. versus the further sunken in hubs on the prius to make the wheels less stable and use less energy to get to speed, a 3MM min/ spacer is needed to clear the calipers.
  18. tihsad
    tihsad Junior Member
    93
    So. California
    i've bought this.. putting them on next week but my car is in the shop because some one hit me. :(
    so jay... i can do it with 3mm spacers? and i need studs as well? then which studs ( size?) should i buy?
  19. tihsad
    93
    So. California
    ah.. one more thing which spring should i buy? suggestions please. im leaning towards tein h tech right now because this web site is local and its only $135.
  20. Jay J
    Jay J Active Member
    469
    253
    Torrance, CA
    Just need the skinnier lugs (without the washers)(to clear the lug holes).and 3mm spacers...stock studs work fine (they still get the req'd amount of turns)
