Most efficient way to charge traction battery while stopped in hot weather?
Discussion in 'Gen 3 Prius Fuel Economy' started by briank101, Jul 25, 2012.
  1. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    Yeah it goes to 1280 RPM if the battery is in the low state ..... and stay there I stop the car NO point to recharge while stopped ...if I KNOW I am going in a minute anways,....
  2. zdenok
    zdenok Junior Member
    57
    Bratislava, Slovakia
    I've just used to "rev" the engine in P after I was forced to start(boot) the car using starting cables after 12V battery was too discharged and I was not leaving yet, so I needed to recharge 12V battery without going anywhere.
    iPhone ?
    Zdenok
  3. markabele
    5,084
    1,782
    Nebraska
    Only time you should force charge the car in a real world setting is before using it in neutral for a little while, such as in a drive through car wash.
    szgabor likes this.
