1. bluejay
    bluejay New Member
    103
    south jersey
    I live in philadelphia, pa and just purchased my prius in October 2005. I was averaging 50 mpg, the first three tanks. Over the Last 6 weeks that has steadily decline to about 25-30mpg. Today I actually only got 16 mpg on a gallon of gas!!! I understand the winter fuel issues, using the heat. . . but this can't be. Should I take in for service? It only has about 1800 miles. I really love the car, but I didn't purchase it for this kind of fuel economy or lack of. Has or is anyone experiencing a similiar problem? It has not been very cold here either, averaging around 37-50.
    Bluejay
  2. twdusa
    twdusa New Member
    53
    Eastern North Carolina
    Bluejay...
    Double check that your PARKING FOOT BRAKE is fully released. Press it all the way down for the PARK BRAKE ON position and then press it for FULL release....be sure that it has released completely to the top of its travel!
    I know this may sound stupid but I rode around for half a day wondering why things didn't seem right with the Prius until I realized that the FOOT PARK BRAKE was depressed about a quarter of the way down. My, MY, the performance was so much better with it off!!!!
    Good luck.....Tom :)
  3. Canuck
    Canuck Member
    605
    Vancouver Island,BC,Canada
    I had the same thing up until the last oil change when again it was slightly overfilled. Had to remove excess using the turkey baster + plastic tube trick in the dip stick hole. Also increased the front tire pressure to 42 and the rear to 40 and the combination increased my mpg by 7 miles/imperial gallon. Still cannot figure out why our mpg is greater on the highway using cruise quite a lot as opposed to in-city/town driving.
    Gary
  4. driveprius
    driveprius New Member
    112
    Delaware
    16 mpg sounds way too low unless you're driving under 1 mile in heavy traffic. 16 mpg is probably way to low for many conventional non Hybrid cars and some SUVs. I live not far from Philadelphia and in suburban driving I've been averaging 40 to 45 mpg during the same time. The worst mileage I ever got was when it was about 14 deg F and I drove hard and drove under 6 miles total. Then I got 29 mpg.
    So the parking brake sounds like the only logical explanation.
    You should start to learn a little about how to coast on a Prius. After you accelerate to a desired speed, lift of the gas, watch all the arrows point back to battery, then press the gas just enough to get all arrows to disappear. On a level road or slight declines you'd be surprised at how fast you can coast with the display showing 99.9 mpg. A benefit of learning a bit of the above, other than getting better gas mileage, is that you'll better be able to diagnose what is wrong with your car if the mileage seems unusually poor. The Prius computer display does a good job of telling you how hard it's working and whether the gas engine is on. The instantaneous mileage meter is pretty accurate. If you get poor mileage, especially as bad as 16mpg you should see the impact on your instantaneous mileage meter. So if you ever find the gas engine never turns off or if it seems your car isn't coasting that easily then these are some clues.
  5. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    Bluejay, I get under 10 MPG. But only first thing in the morning with a cold engine, going up a hill, and only for 100 yards. How many miles were at 16 MPG?
    The instantaneous MPG readout can be deceptive. On the highway I've seen it drop below 20 when I gunned it to pass, but the five-minute segment was over 50 MPG.
    If you've gone miles at 16 MPG, something is definitely wrong. If it's not the brake (easy to hit by accident) then you need to take it in to the dealer.
    Oh, BTW, welcome to PriusChat, too bad this had to be your first post.
  6. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    We're all gonna need a little more information in order to properly address your concerns. And we will try our best. There's nothing more disturbing than an unhappy hybrid driver. :)
    Evan (efusco) wrote a very thorough article discussing causes of poor mileage and providing tips on how to improve your mileage average.
    Check it out: http://priuschat.com/forums/kb.php?mode=article&k=23
  7. efusco
    efusco Moderator Emeritus
    19,891
    1,195
    Nixa, MO
    Check your tire pressures...not tomorrow, right now. Go out and do it. The ONLY times I've experienced sudden dramatic drops in MPG were when I had a flat tire...not totally flat, but it doesn't have to be, a drop to 20psi or so will trash your mileage.
    Beyond that, you've gotta give a LOT more information. Winter is a killer, and an even worse killer if you do very short trips with no chance to warm up. Have your driving conditions/commute changed since your 50mpg tanks? And noticable change in the performance of the car...check the air filter (the one for the ICE, not the cabin).
    Also, how on earth did you determine you got 16mpg on a gallon of gas? I know of no way to determine that without completely draining the tank dry then adding exactly one gallon and driving until the car stopped with a dry tank 16 miles later.
  8. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    The only time I had a sudden drop I had low pressure in one tire. Filled it never figured out why. Maybe I hit a curb. I would check you tire pressure.
  9. efusco
    19,891
    1,195
    Nixa, MO
    One other thing (ok, two), check both your AC setting (no need to turn the heat up any higher than about 68 degrees unless you have Raynaud's or drive naked. And check that you are not accidently driving with the defroster on...that's an MPG killer.
  10. jacaufie
    jacaufie New Member
    104
    Hillsboro, Oregon
    Is the advice about not using the defroster limited to front, back or both?
  11. efusco
    19,891
    1,195
    Nixa, MO
    I'm not advising to 'not use' them, but there's usually no reason to leave them on all the time. If you need them, use them. But the impact is the same..front and back.
  12. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    Well.. i don't see a location on your info..
    Have you thought about cold weather? Leaving defrosters on will kill mpg.. like.. kill it.. very badly.
    I personally would rather dress warm, and not have the heating system on.. or.. on low. try not to use the defrosters. it drains that battery pretty quick. It also keeps the engine on.
  13. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    For my first 5000 in San Diego county I was getting 40-41, now that I am at 6000+ I have gotten up to 43-44 for my last three TANKS!
    1. I am going 65-70 most of the time
    2. I am keeping an eye on the tire pressure
    3. I keep the AC at 72 most of time
    4. My car wont even move with the parking brake on but if you use the engine brake you will definitely decrease your mileage.
    5. I rarely use CC
    Any further input from bluejay??
  14. efusco
    19,891
    1,195
    Nixa, MO
    That pretty well addressed the location issue I think.
    But yea, the weather there's going to be fairly cold and cause some impact.
  15. bluejay
    bluejay New Member
    103
    south jersey
    Thanks everyone for your information. I have downloaded the info on how to get better mpg---As for additional information, the week after I got the car i drove to Northern Virginia, great experience and milage 50+. This continued for about a month afterwards. The first cold week--down to 35-39 and it has continued to drop eversince--averaging about 25-29 MPG. My work is 6 miles, city. Takes me 15-25 minutes depending on traffic. I haven't put an real highway miles on since my virginia trip.
    I also notice the blue bars won't charge past 8 bars and mostly stay in the 7-8 area. Reading the manual has not helped at all to figure any of this out.
    I reset the trip odometer (A) after each fill up and (B) after each individual gallon bar so I can keep track on MPG per Gallon--The 16 mpg happen today on my way home from work. Bluejay
  16. EricGo
    EricGo New Member
    1,805
    Albuquerque, NM (SouthWest US)
    Really good advice above.
    Presuming you are not driving with all the warning lights lit, the engine is probably ok, and you have a whole lot of unwanted friction somewhere.
    Stuck tire brake ?
    Partial handbrake ?
    Just saw your last post. Perhaps you should try something of a standardized test: Try driving for about 5 minutes, and then go out on the highway and see what a five minute bar is with cruise set at 50 mph. If ambient temperature is above 40 F, mpg below 50 would be reason to think a problem with the car is present.
    Good Luck. I expect this will get solved.
  17. Salsawonder
    1,897
    47
    La Mesa California
    I would also recommend a more reliable tracking method. I find that filling up the tank can vary alot depending on what gas station I fill up at. Try using the same place. The "bars" are not that reliable (as with most cars) for determining gas mileage.
  18. TonyPSchaefer
    14,816
    2,499
    66
    Oh, I'm sorry. Actually, in terms of a very short drive, I'm extremely envious. However, since this thread is about mileage, I'm sorry that your engine never has time to warm up, that the catalytic convertor barely gets warm, that you might rarely have the opportunity to EV.
    Yeah, that's a tough one. a six mile commute is NOT good for mileage.
  19. bluejay
    bluejay New Member
    103
    south jersey
    I'll check out these suggestions, needless to say, I won't be driving naked any time soon and I'll post to let everyone know what's happening. Another thing--any brands of fuel better than others --I've been using BP? Thank you kindly, BB
  20. GreenMachine
    GreenMachine New Member
    760
    Vermont, USA
    We had a poll on brands of gas with some good discussion at
    http://priuschat.com/index.php?showtopic=13054&hl=chevron
