prius v - charging system not up to standards
Discussion in 'Prius v Technical Discussion' started by syscon, Jul 30, 2012.
  1. syscon
    syscon Member
    329
    43
    Edm. Alberta
    After driving Prius v for few months in the summer I've noticed that Prius v charging system is not adequate, I connected the charger and noticed that the battery was charge was between 25 to 50% level. Yes I do short trips but it shouldn't make any difference.
    It seems to me the battery has to be charger with an external charger once a week.
  2. rjparker
    10,580
    6,636
    If you are talking about the 12v battery I would say take it back under warranty.
  3. camry25
    camry25 Junior Member
    46
    l.a.
    If you don't use your car for several days, is battery completely dead? My (old) non-hybrid Camry has this problem. Replaced battery several times, alternator. Maybe test for ghost current draws?
  4. mudmanrv
    mudmanrv Member
    176
    17
    NE Indiana
    If it set on the dealer lot for a length of time - they probably "killed" the battery letting it run flat 1 too many times...
    take it back- get a new one under warranty... it may also have a shorted cell causing it not to take a full charge and go flat quickly. try a new one first -
    I got mine fresh off the boat and delivery truck with 9 mile (pre-delivery inspection) ... so it didn't set in the shop for more then a couple days since it arrived in the states... I haven't had any trouble - driven daily, mon. thru fri. rarely on weekend.
  5. Flying White Dutchman
    4,376
    313
    Short trips matter specially with today cars with lots of standby computers
    -Tapatalk
