Quick Question About Tire Weight
Discussion in 'Gen 3 Prius Fuel Economy' started by FUUFNF, Aug 7, 2012.
  1. FUUFNF
    FUUFNF Forum Lurker
    210
    30
    Long Beach, CA
    Just a quick question about tire weight. Do they weigh more inflated or deflated? I'm guessing deflated, but just wanted to verify before I bothered deflating them. I need to ship a set of rims & tires, and obviously the lighter, the better. Thanks in advance.
  2. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    They weight more inflated, but not much, may be a few ounces tops. More matter (air) = more mass.
    FUUFNF likes this.
  3. bisco
    52,385
    :D
    F8L likes this.
  4. FUUFNF
    FUUFNF Forum Lurker
    210
    30
    Long Beach, CA
    Thanks.
    I ran a quick test, the difference was about 3 pounds (and I didn't deflate the tire all the way). Approximately 39 pounds inflated, and 36 pounds deflated.
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Thanks. Wow. I did not do any calculation, I just pull that few Oz number out. :p
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
    It should not be able to measure a difference unless you are using a scale that can measure ounces or smaller.
  7. bisco
    52,385
    that's some heavy air.
  8. WE0H
    WE0H Senior Member
    3,247
    528
    Fill 'em with helium if you want to lighten the load.
    Mike
  9. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    3 lbs is too much for the relatively small amount of air in tire. You might have water in your air.
  10. walter Lee
    1,126
    376
    Maryland
    You know - Mike - you might have something there. ;) If one inflated all four tires with hydrogen or helium instead of air - the Prius' curb weight would be a few pounds lighter wouldn't it? :D. I wonder if Toyota thought about making a hybrid synergy drive Airship/Dirigible that got 100 mpg. In the air there are no traffic lights, stop signs, or speed bumps.:D
    WE0H likes this.
  11. SuperGLS
    SuperGLS Member
    200
    52
    Washington DC
    ^I'm happy to test the prototype!
  12. mad-dog-one
    1,181
    421
    Whereabouts Unknown
    Those hydrogen-filled tires would be really interesting with hot brakes and sparks. Pop, k-boooom, micro-global warming; as your Eco-friendly car is quickly recycled back into the environment.
  13. WE0H
    WE0H Senior Member
    3,247
    528
    Bring along the hotdogs and a long cooker stick to make lunch :)
    Mike
  14. walter Lee
    1,126
    376
    Maryland
    Dang! Another hopeful fantasy shot down! :p:whistle:
    And here I was just hoping to that next generation Prius would float away pass the competition. :love:
