My Prius C mods so far...
Discussion in 'Prius c Accessories and Modifications' started by hypnosismcb, Aug 8, 2012.
  1. hypnosismcb
    hypnosismcb Junior Member
    ladera ranch
    I have spent many hours working on my car, and all have been worth it!
    From front to back:
    Black gloss toyota emblem on front and rear, carbon fiber underlay
    Tinted turn signals above fog lights and on mirrors
    HID H11 5000k 35w kits on low beams and fog lights
    HALO platinum white 5000k high beam bulbs
    Black gloss headlights
    Carbon fiber wrap over hood, door pillars, and gas tank door
    Toyota of Japan OEM rain guards
    Tinted windows (not done by me)
    LED parking lights, front and rear marker lights, dome lights, and license plate lights
    Engine block heater
    Cusco strut tower bar
    TRD lowering springs (don't ask how)
    Cusco rear sway bar
    Cusco front sway bar (next month)
    Cusco lower arm brace (next month)
    Dash kit (from Juiced Hybrid)
    TRD emblems for front grill and rear hatch
    TRD seat belt covers and stickers on car
    Factory all weather floor mats
    Scanguage 2
    I will be doing a lot more soon.
  2. Native2PS
    Native2PS Member
    144
    66
    Kihei, HI
    nice job!
  3. DamonBoost
    DamonBoost New Member
    27
    What size wheels/tires are those?
    How much did the TRD Lowering Springs lower the car?
    Did they affect the ride quality much?
  4. loaddown
    loaddown Loaddown
    34
    St Lucie West, FL
    Show us the dash and other details.
    Daze likes this.
  5. priusCpilot
    priusCpilot Active Member
    663
    210
    LA
    Nice start! Can't wait to see more!
  6. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    I'd love to hear more about how you blacked out the headlights. ...and more pics too! :)
    How do the TRD springs and rear-sway-bar affect handling?
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    I bet the car feels like its on rails now! :)
  8. Tideland Prius
    16,587
  9. hypnosismcb
    ladera ranch
    Thanks for all the replies!
    Headlights:
    It took me around 8 hours to black out the headlights because 1. I didn't know how to remove anything except for one hidden bolt on the headlight assembly to remove it off the car, and 2. I had to wait for the paint to dry. I bought a heat gun from home deopt because I don't agree with baking the headlight assy. If you use the low setting on the heat gun and wave across the glue on the backside, a few minutes should be enough to pull apart the glue after you have taken out the screws for the lens/housing. MAKE SURE YOU HAVE EVERYTHING IN A DUST FREE ENVIRONMENT! There is one screw that has a special fitting, and I didn't have the tool for it. All I did was cut the black tab that the screw goes into. BE VERY CAREFUL ON PULLING THE TABS AROUND THE LENS WHEN REMOVING! After you have applied the heat gun, the tabe become very fragile and I broke a few. There are a few screws to take the chrome piece off of the backside of the assy. After I had the chrome piece off, I used very fine sand paper and water to prep the surface and remove the top layer of chrome. I used a black gloss spray paint and evenly coated the whole piece a few times, an hour between coats. After the last coat started to dry (I was slightly in a rush which is stupid) I put the assy. back together. After screwing the housing screws back in, I used the heat gun for a few minutes and then I put everything back in place. It was a long process, and it wasn't easy, but I love the way they look now.
    TRD lowering springs and sway:
    The springs lowered the car about 2 inches. The car's lower stance helps with the handling and body roll. I guess in Japan they have a TRD Prius C with sportivo springs. They look way different than these on the rear but I still really like the feel of them. Not too bad on uneven roads, but with 4 people, it is ridiculous how much it bounces on the freeway. The rear sway bar from cusco and the front strut tower bar from cusco really work well together. I installed the strut bar first, and then a week later, I put on the rear sway bar. I IMMEDIATELY noticed a difference in the rear! It feels like the rear of the car is almost locked to the gound. The rear sway bar really compliments the front strut bar. I am still installing the cusco front sway bar and lower arm brace at the beginning of next month once it comes in. I definitely recommend the rear sway bar! It is easy to install and it takes a small amount of time (if you have a jack and stands).
  10. DamonBoost
    27
    Are those 15" or 16" Wheels on it?
  11. Tonyzenmaster
    Tonyzenmaster New Member
    22
    How's the mpg on the car now?
  12. Hyper_PriusC
    Hyper_PriusC Member
    83
    55
    San Jose, CA
    +1 curious to see the dash kit
    Looks great. keep up the good work. Any plans on new rims?
  13. Hyper_PriusC
    Hyper_PriusC Member
    83
    55
    San Jose, CA
  14. dliet
    dliet New Member
    Nice! like everyone else I would like to see more pics, especially of the changes you made to the exterior.
  15. dolfanpete
    dolfanpete Junior Member
    60
    Naples, Florida
    was the fog lights hard to install?
  16. Bluec4
    Bluec4 New Member
    Looks great I was wondering where you got the black emblems?
  17. phenoyz
    phenoyz Member
    108
    nevada
    nicely done ! keep up the mods !
  18. karabits
    karabits Member
    51
    Minneapolis
    Nice work!
    I'm considering putting in HID fogs but suspect they may dazzle oncoming traffic. Have you had anyone flash you their brights after installation? I don't believe the headlights would cause any issues, since they are projectors. I haven't had anyone flash me about mine.
    Thanks!
  19. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    I haven't had any issue with my headlights. They are super bright compared to the factory, but they are cut off because of the projector lens. It's very nice.
  20. Steven Harvey
    Steven Harvey Junior Member
    96
    Guelph On. Canada
    Do you plan on racing your Prius?
