Wheel Trim Ring Taste... Keep them on or Pop them off?
Discussion in 'Gen 2 Prius Main Forum' started by MSAGRO, Jul 20, 2012.
  1. ON: Makes the wheel look fuller and elegant
    46.2%
  2. OFF: Enhances the "Mag" wheel effect and looks more sporty
    53.8%
Multiple votes are allowed.
  1. MSAGRO
    MSAGRO 2010 Prius Five with Advanced Technology Package
    259
    227
    Portland Oregon
    What is your preference? Keep the trim ring on, or have them taken off.
    What looks better?
    Trim Ring On:
    Trim Ring Off:
    Side view On:
    Side View Off:
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    If they are broken, like two of ours are, then I vote pull them. Too bad the wife is over ruling me on this one. It's her car, I just drive it and maintain it. Hence my vote of keep them on...
    Ron (dorunron)
  3. Patrick Wong
    18,200
    6,500
    1. The trim rings help to protect the aluminum wheels so if members of your household like to use the Braille method when driving, it may be wise to keep them on.
    2. If you wish to replace the broken trim rings, you can buy replacements for around $38 each plus shipping from your favorite Toyota dealer selling discounted parts over the web, for example toyotaworld.com
  4. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Definitely on. It makes the wheel look bigger which is the main problem with Prius wheels/tires, they look too small on the car. I might add them and put my hubcaps back on vs. the all the black alloy.
  5. donj51
    donj51 Junior Member
    Credar Creek Wind Farm - Grover, CO
  6. Oldwolf
    Oldwolf Prius Enthusiast
    825
    110
    NC
    2016 Prius v wagon
    I liked them off until I scratched one of my wheels. Now I leave them on.
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Off. Sell covers on eBay for $100.
  8. dorunron
    3,318
    1,105
    Houston, TX
    Patrick,
    I called Jake today at toyotaworld.com (Champion here in Houston) looking for the trim rings that MSAGRO is talking about. Can you confirm if the part # for those rings is 4260247030? Looking on their website, they don't list that particular ring for the 09, but that is what seems to be on all the 09's I have seen including ours. I am definitely looking for two rings to replace the two that are broken, but am hesitant to order online without verifying the number. Jake @ toyotaworld.com gave me the number. Been googling the number, and am not 100% positive it is the right one. I have found that number listed on some sites that show the correct picture, but they also show the car year 2004 - 2006, which doesn't make sense to me.
    Any help with this would be greatly appreciated.
    Jake quoted that part # at 38.96 each.
    I try not to use the Braille method, but it does look like someone before me did. Original owner was a rental car company out of Florida... Bought this one as second owner (Certified) at Champion here in Houston.
    Ron (dorunron)
  9. Patrick Wong
    18,200
    6,500
    Hi Ron,
    I can confirm that 42602-47030 will fit 2004 and 2007 wheels. It likely will fit the 2009 but I do not have personal experience with that. Sadly, my daughter and wife are known to occasionally use the Braille method and I therefore have bought a few replacement trim rings over the years.
    dorunron likes this.
  10. dorunron
    3,318
    1,105
    Houston, TX
    Patrick,
    Thank you very much for your help. I really do appreciate it.
    Ron (dorunron)
  11. bugly64
    bugly64 Junior Member
    66
    Marysville, CA
    Definitely leave them on. They are there for added mpg.
  12. MSAGRO
    259
    227
    Portland Oregon
    ? The air flow horizontally passing through the area of the wheel will affect MPG?
  13. bugly64
    66
    Marysville, CA
    I read it on the fuel economy forum a while back. I am sure it is not that much of a factor.
  14. Ryanpl
    Ryanpl Active Member
    780
    158
    Brooklyn, NY
    I took em off and think the car looks better
  15. Paul R. Haller
    285
    43
    Walnut Creek
    I went onto ebay and bought 4 wheel covers for less then 40$. They are brand new but not made by Toyota. They are a perfect match fot the trim rings on the car. Now I have a couple of spairs.
  16. dorunron
    3,318
    1,105
    Houston, TX
    Toyota Prius Trim Rings | eBay
    Not OEM, but if they fit and stay on, there they are.
  17. PriusDIY
    PriusDIY Junior Member
    49
    Minneapolis, MN
    I like them off. To each their own :)
  18. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Why does my preference matter? It's your car!
    Last time I checked, the car does not drive "horizontally".
    If wheel profile was so important to MPG, you'd either see solid hubcaps, or fenders covering the wheels... it just ain't that important!
