2010 rear wheel bearings
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bart Baeckelandt, Aug 8, 2012.
  1. Bart Baeckelandt
    Bart Baeckelandt Junior Member
    So I just turned 100k a couple weeks ago and now I think my rear wheels bearings are going I have a loud noise coming from the back of the car. I think its coming from the drivers side.
    so where to go to get the best prices on replacements and how bad of a job is it to replace?
    Appreciate feedback
    One other thing is it seems like there are hub assemblies and bearings which way to go??
  2. smassey22180
    smassey22180 Junior Member
    37
    Sacramento, CA
    This is what I use to find bad wheel bearings. Jack the car up. Spin the wheel. Probe the back side of the hub. Compare left to right sides. Amazon.com: Lisle 52500 Mechanic's Stethoscope: Automotive
    Does the noise change when going from pavement to concrete? If it is constant it is wheel bearing. If the pitch changes it may be a bad tire.
  3. The Critic
    The Critic Resident Critic
    3,193
    2,332
    CA
    The job is REALLY easy. After removing the rotor, all you need to do is remove the 4 bolts and disconnect the electrical connector holding it in. It's a job that you can do in about 30 min if you are working fast.
    iPhone ?
  4. El Dobro
    El Dobro A Member
    7,079
    3,259
    On the way to work a couple of days ago, I heard a crack and then the snap, crackle and pop of a rear wheel bearing. When I got to work, I jacked up the left rear wheel and spun it. Nothing. I got on my hands and looked underneath. A large twig jammed itself into the plastic wheelhousing and was dragging on the street. It sounded just like a bad wheel bearing.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    OP, what is your general location? Another member had his rear wheel bearings go out prematurely and thought it might be because of the damp, salty location. I will try to find the thread... [edit] here it is.
  6. Bart Baeckelandt
    Well I ended up replacing the passenger rear wheel bearing I was surprised how rusted the part was already but I guess it was to be expected in Michigan
  7. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Should replace them in pairs don't you think? ;)
  8. Bart Baeckelandt
    Well I taled it over with my mechanic and there was hint of an issue on the other side so I will haold off until next month to do so
