My Duinomite Mega Canview V4 equivalent Project
Discussion in 'Prius PHEV Plug-In Modifications' started by lopezjm2001, Jul 19, 2012.
  1. Yes
    11 vote(s)
    100.0%
  2. Prefer to use Android Torque device
    0 vote(s)
    0.0%
  3. Prefer to use Scangauge
    0 vote(s)
    0.0%
  1. planetaire
    planetaire Plug in 20 kWh 85 km/h or > 208km range
    190
    139
    France
    Converter temp: In the frame 21, byte 3. (This is the most important in OOG mode.)
    Inverter MG1 in the frame 23 byte 8.
    lopezjm2001 and dave77 like this.
  2. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
  3. jdh2550
    jdh2550 Co-Founder, Current Motor Company
    317
    249
    Ann Arbor
    CAN Commands update:
    Commands are written, compiled and debugged up to the point where it runs as expected on the bench (with no CAN hooked up!). i.e. all the parameter handling is working and the rcv command correctly states "no data".
    Next up is to hook it up to the Prius and see if it actually collects data. Chances of it working "out of the box" are no more than 1 in 100! Chances I can make good progress and debug it with 1 more evening of work - about 50/50...
    Watch this space...
  4. Flying White Dutchman
    4,376
    313
    Is this based on the open dmbasic or closed mmbasic?
    -Htc Tapatalk ( sorry for auto spell correct )
  5. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Recommend moving this project to the free Atmel Studio 6 IDE. Built-in compiler, debugger, and emulator would allow the use of complete instruction set and hardware features of your chosen MCU. This should fix your speed and error problem. Atmel is in the CAN market so there are app notes and software tools available.
    Just a suggestion for ver. 2.0 of your project.
    Atmel Studio- Atmel Corporation
    Networking - Automotive Application- Atmel Corporation
    CAN/VAN Networking Automotive Solution- Atmel Corporation
    TI/National is also a good source of Automotive MCU/CAN implementation information.
    I use both TI and Atmel IDE's, Eagle PCB design, and Autocad LT on an Atom based netbook. No 3D of course.
    NortTexSalv04Prius likes this.
  6. lopezjm2001
    1,146
    407
    Sydney Australia
    I am sticking with using mmBasic merged with CAN commands. It's simplicity makes it user programmable allowing the PHEV user to customize the program to their own situation.
  7. lopezjm2001
    1,146
    407
    Sydney Australia
    Most likely JDH2550 new CAN commands can be built with either mmbasic or DMbasic source code. Just need to follow the instructions JDH2550 wrote.
    http://priuschat.com/attachments/instructions-for-porting-can-commands-into-mmbasic-pdf.40626/
    MmBasic is better and open sourced. DMbasic CAN commands source code appear to be closed source even though you can easily download it from Github.
    dave77 likes this.
  8. lopezjm2001
    1,146
    407
    Sydney Australia
    I am getting readings as high as 108 degrees Celcius and usually aroud 45 degrees Celcius and temperature changes quickly. Not sure if byte 3 of frame 21 for 21C4 is correct. What kind of temperature readings are you getting for the converter temperature?
  9. Flying White Dutchman
    4,376
    313
    I got it the wrong way around? Dmbasic is the closed one?
    I tough mmbasic was the closed one
  10. lopezjm2001
    1,146
    407
    Sydney Australia
  11. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    I think planetaire take 21 as byte 1 so byte 3 should be correct. In Torque, that byte location is 'F'. Perhaps you should check your formula? 1.8 * F - 58 is in Fahrenheit, for Celsius you should use F - 50.
    Working your no. backwards, 108 = 1.8 * F - 58 => F = 92
    If you use F - 50,
    92 - 50 = 42
    Vincent
    lopezjm2001 likes this.
  12. lopezjm2001
    1,146
    407
    Sydney Australia
    Thanks. I totally forgot that there is a 50 degree Celcius offset.
  13. jdh2550
    317
    249
    Ann Arbor
    Hi James,
    I'm using exactly those tools for my YaPIP project (also documented on this site) - I'm using an eval kit with two CAN ports and an LCD screen.
    However, the goal of this thread is to use the DuinoMite Mega because it's so cost effective and feature ready right out of the box. CAN, VGA, USB, Sound, SDCard - right out the box for only $40. BASIC makes it easier for the non software engineers on this thread to write the high level code.
    If you want to get to the "bare metal" then it's a PIC32 and you can use any appropriate IDE for the Microchip range. However, it comes with a choice of two flavors of BASIC and the ability to add new commands to the interpreter - so it's relatively straightforward to fix all the timing issues by moving appropriate processing down into the interpreter and leaving the high level commands in BASIC. It's actually a good division of labor - lopez is working on what he wants to achieve in BASIC and I'm doing the bits that need to be speeded up in the C-code.
    To answer FWD's question: both - but mmbasic isn't "closed".
    Longer answer:
    The two flavors are:
    DMBasic - this is Olimex's version that they ship on the DM Mega. It works with CAN out of the box. It's an older "flavor" of BASIC and requires line numbers and GOSUB/RETURN for function-like calls. It's open-source and licensed via GPL. It's hosted on GitHub.
    MMBasic - this is Geoff Graham's original version that Geoff created for his MaxiMite design. MMBasic 3.2 is a more modern implementation of basic and implements "proper" functions and subroutines as well as dropping the need for line numbers (it's backwards compatible with line numbers).
    The DuinoMite hardware is a clone of the MaxiMite plus extra features. There's some disagreement between the two camps and Geoff was unhappy with their using MMBasic. So, as of version 3.2 he created a more restrictive license. However, it is not a "closed" license as some folks state. The source can be requested and can be modified in any way for personal use - but can't be distributed without Geoff's permission. The source can be requested from the MMBasic website.
    MMBasic doesn't have CAN out of the box. However, it's straightforward to port the CAN commands (copyright of another party). However, I'm told by the copyright holder of the CAN implementation (Frank Voorburg) that GPL licensed code can't be included in the MMBasic distribution. So, to add the CAN commands one has to request the source code from Geoff, retrieve the CAN source from GitHub and then use the freely available tools to put them together (that's what my instructions describe). If you do that then you have a perfectly legitimate copy of MMBasic for private use.
    Clear as mud, right?
    Bottom line is that any CAN commands that I write that are based off of Frank's original will be GPL'd and thus you'll have to build 'em yourself for private use. The commands will work in either DMBasic or MMBasic - I prefer MMBasic and the instructions that I distribute are for MMBasic.
    In the future (when I get a round tuit) I'm planning on rewriting a CAN implementation from scratch. At that time I'll be copyright holder and can license it in such a way as to allow it to be rolled into an official MMBasic distribution. Not sure when/if I'll actually do this - because there's more pressing needs for my overall goal (see YaPIP).
    Peace, love and plug-ins!
    John H.
  14. lopezjm2001
    1,146
    407
    Sydney Australia
    It turns out that the Converter temperature is rxData(2) for frame 21. So if rxData(0) = byte 1 then it is correct. I now get a normal reading for converter temperature. It peaked at 45 degrees celcius during my trip home in OutOfGas mode. See photo of my latest Canview Screen of my Duinomite Mega.
    dave77 likes this.
  15. Flying White Dutchman
    4,376
    313
  16. planetaire
    190
    139
    France
    Yes, byte 1 = 21 so temp is your rxdata(2)
    I have already read more then 55°C (see picture using 22 kW) and more then 60°C in an other test, using full EV power
    dave77 and lopezjm2001 like this.
  17. lopezjm2001
    1,146
    407
    Sydney Australia
    This guy claims that Frank used a hacked version of mmBasic 2.7. So that means that the only difference between mmbasic 2.7 and DM basic 2.7b are the additional CAN commands. I just want people to see the correct perspective between mmbasic and DM basic. So the way I see it DM basic is not really a different flavor. Just the same flavor sprinkled with CAN commands.
    dave77 likes this.
  18. jdh2550
    317
    249
    Ann Arbor
    I think you're misunderstanding what I meant by "flavor" (which I confess is a non-technical term!). Branches would be more appropriate.
    DMBasic started from MMBasic 2.7 and several changes were made to support DM (it's not just the CAN commands that are different). Thus, one would say, DMBasic forked to it's own brance at MMBasic 2.7. The branches are now separate and are unlikely to merge back together.
    Thus the DMBasic interpreter is functionally equivalent to MMBasic 2.7 interpreter. However, MMBasic 3.2 is a major upgrade to the BASIC interpreter. It's the updated interpreter that gives us structured programming.
    It's easy to add CAN to MMBasic 3.2. I'm not sure it would be easy to add the BASIC interpreter upgrades back into DM. So, I think DMBasic is likely to remain "stuck" at 2.7 whereas MMBasic has a version 4.0 coming out soon (although that's mainly to support the new color MaxiMite).
    I tried to join the "official" forum for DMBasic but never got a response from the board administrator (99% of boards I use automate sign-up stuff). I prefer the style and capabilities of the 3.2 interpreter so I'll be concentrating on adding DM unique functions (such as CAN) into the MMBasic source tree.
    Here's what I know:
    1. Both DMBasic and MMBasic work and meet the goals of the authors. I make no claim as to which is "better" or "worse".
    2. DMBasic requires line numbers and has CAN built in out of the box.
    3. MMBasic provides structured programming but the individual user has to compile their own version for CAN support.
    4. DMBasic programs that access CAN will run on MMBasic as long as step 3 has been completed.
    5. MMBasic programs that use functions and subroutines but don't use line numbers will not run on DMBasic.
  19. Flying White Dutchman
    4,376
    313
    even in mmbasic i now stil use line numbers because that possble and i think better if anywone would go beack to Dmbasic with line numbers and use the same program code
    i also like line numbers -)
  20. jdh2550
    317
    249
    Ann Arbor
    I'm happy for you ;)
    It's not that I don't like line numbers. I don't even mind GOTO!
    It's that I miss being able to write functions and subroutines and have those functions be clearly named and have local variables...
    But to each their own. :)
