Stage 10 Electronic Shifter available now
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Tracksyde, Jun 21, 2012.
  1. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Were u lucky yesterday?
  2. Manila Ice
    Manila Ice Hybrid and V8 Lover
    96
    63
    Chino Hills
    NO....But I'm Lucky today :D
    sfv41901 likes this.
  3. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    take lots of pics and post it here once you install it :)
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Lucky in what way??? :D
  5. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    Got mine in now, everyone was right..... 6 min to install and I had to find a srewdriver to boot.
    This shifter is great.......................
    One question (I'm not going to try this)
    Can you accidently shift into R while driving in D or B?
  6. Steve Type-4
    Steve Type-4 Trading HP for MPG
    174
    102
    SoCal
    If that happens, the transmission will shift into neutral. According to Stage 10:
    I ordered the silver/green combo. Should be getting mine next week :cool:
  7. striker308
    302
    43
    I back out of the driveway in R and at the end while still rolling hit D, it doesn't go to N it drives forward.
    maybe that's because of how slow I'm still rolling backwards but since it didn't go to N like what I've read before I ordered it I started thinking "what if"
  8. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    From what I remember, the stock shifter behaved the same way (because I'm pretty sure I've done what you described). And from what I read (here), the stock shifter also goes into N if you try to hit P or put it in R while the car is moving (probably at speed like you said).
  9. bisco
    52,366
    hold down the power button for 3+ seconds.
  10. striker308
    302
    43
    ??????? (n)Huh?
  11. bisco
    52,366
    the answer to 'what if'?
  12. jabecker
    jabecker driver of Prii since 2005
    448
    78
    Portland, Oregon
    Finally found 10 minutes and dropped mine in. Silver and green. I'm loving it!
    One thing I noticed: you can't put the car in any gear - even N - if the parking break is on.
    My standard start-up procedure is: boot up, foot on break, car in D or R, release parking break, foot off break and on gas, go. That worked fine with the little joystick. With the Stage 10 in, when I tried to put the car in any gear I got three short beeps. I actually took the whole thing apart again and checked all of the connections before it occurred to me to release the break. Yeah.
    That's why it took me 10 minutes instead of 6. :rolleyes:
    Steve Type-4 likes this.
  13. striker308
    302
    43
    I don't think I have ever used my parking (emergency) brake in either the 2006 or the 2012.
    don't you trust the P?
  14. Manila Ice
    96
    63
    Chino Hills
    will do Im just kinda busy.... I got the Silver/GREEN and for those who wants to find out what kind of green is on the shifter....its the same green as the turn signal light arrows on the dash board and the EV/ECO/PWR icon/symbol on the dash also when you press one of these buttons!
  15. bisco
    52,366
    not on a decent grade.
  16. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I've always used the p brake.......its a habit. Don't want the extra stress on the motor/tyranny mounts on any of My cars.
  17. jabecker
    448
    78
    Portland, Oregon
    I've always use the parking brake with all of my cars. It's just habit.
    The owner's manual even says to do it in the order I mentioned above.
    Start: foot on brake, turn on, D or R, release p-brake, foot off brake, gas.
    Stop: foot on brake, set p-brake, P, turn off.
    I'm obviously going to have to slightly change my habit. But I think I can get used to it. :)
  18. jabecker
    448
    78
    Portland, Oregon
    Here's mine. The green is different. It's a greener green, while the other buttons are a yellow green. It shows better in the daytime picture. I don't mind the difference. As someone mentioned, the green in the Stage 10 matches the green on the MFD.
  19. striker308
    302
    43
    Looks great!
    I installed the carbon fiber in blue.
    That green does flow nice with the rest of the display, Did you cover the LED "light from above" for this picture?
    After driving around last night I noticed that the higher gloss on the carbon fiber created a bit of a glare with the LED, I'm going to cover it with tape to see if I like that better, if so I'll disconnect the power to the LED.
  20. jabecker
    448
    78
    Portland, Oregon
    Thanks. Yes, I just stuck my thumb over the LED "light from above" because it created glare at the camera angle. It's fine when I'm driving, though. The lower gloss on the silver keeps the glare to a minimum.
