3rd fuel up. A little disappointed with my fuel economy
Discussion in 'Prius c Fuel Economy' started by hur00003, Jul 25, 2012.
  1. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    Yeah, as others have said, economy drops off precipitously as you get to the faster highway speeds. This is why I get really nice economy on slow BC highways (85-100 km/h) and it gets noticeably worse when I cross the border and speed limits are 75 mph. It's the wind resistance - our little city critters are less aerodynamic than the liftback.
    Galaxy Nexus ? 2
  2. tonia taffaro
    tonia taffaro Junior Member
    83
    what does ICE stand for?
  3. tonia taffaro
    83
    the wife runs late in the morning....:rolleyes:
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Internal Combustion Engine
    tonia taffaro likes this.
  5. jjmcubed
    jjmcubed Junior Member
    Sorry, Eo? That mean extra octane?
    First post and new driver of a C 4. Wanted a 2, but there were only 9 in California when we looked so they wouldn't trade. Hello everyone!
  6. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    E zero, means no ethanol. Welcome jjmcubed!
  7. hur00003
    hur00003 New Member
    Portland Oregon
    My trip home from work, i never go above 40mph, but it's always a very casual drive up the hill. It's just very steep. I wish there was a way to pre warm up the engine, while i was at work.
  8. Erikon
    819
    105
    Rochester, NY
    Install an engine block heater, but you'd need to be able to plug into an electrical outlet where you're parked.
  9. happywithmyc
    happywithmyc New Member
    24
    i now get after some breaking in , i now get about 47 mpg now average at 3700 miles
  10. Boojoo007
    Boojoo007 Junior Member
    64
    when you say don't over use EV mode, do you mean do not press the EV button or drive in the EV section on the Eco Score -Screen
  11. F8L
    19,011
    4,083
    Grass Valley, CA.
    Don't push the EV button until you learn enough about the hybrid system to know when to use it properly. Other than that just drive the car using normal hypermiling techniques and add in the more complex stuff over time. :)
    RocMills likes this.
  12. chivazo
    chivazo Junior Member
    31
    San Francisco Bay Area
    Something very important to do! check your tire pressure! When I bought the car they came at 36psi and I increased it to 40-41, I am getting 54mpg freeway, and about 59mpg average. When I drive on flat roads under 40mph I have got up to 80mpg's. You have to learn how to avoid stoping on stop lights by looking ahead of the road and braking gradually to re-generate the battery. Once you break in the engine you will probably get better mileage. If your hills are pretty stiff you might not get much better than 40mpg's but you could make up the difference going down hill and flats if you learn how to drive it correctly.
  13. chivazo
    31
    Go down to 65mph and you will see a huge differece on fuel economy. I'm getting 50-56mpg with 41psi on the tire pressure.
