EV Miles estimate after Full Charge LOW
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Bill3888, Jun 27, 2012.
  1. bisco
    52,091
    i wonder what happened to portland pip?
  2. Robert A Leahey
    Robert A Leahey New Member
    Do you have an update after having taken the care in to the dealer? I experience the same thing with regard to the projected range after a charge falling...mine is down to 8.8 miles. However, I know I'm going much further than that on the charge. I'm going about 14 miles as far as I can tell. It has taken me a couple of weeks to start figuring out the best time to use the EV, without a HV boost. I find it best on highways, and particularly up hills.
    I'd be interested in knowing what your dealer had to say about the issue, if you'd share....
    Thanks,
  3. DLee
    DLee Junior Member
    81
    I believe this describes how my PIP behaves
  4. bisco
    52,091
    you can't determine how far you can go on a charge, using hv some of the time. try taking some ev only trips until low charge starts the ice.
  5. Bill3888
    Bill3888 2012 vs 2006
    25
    Riverside, Ca
    After charging place car in READY and then look at the Estimated Miles for EV. Then push the OFF button for the heater /AC system to get the fan off. Watch the EV estimate when you do this and you'll see a jump of 1.0 to 1.4 miles in the EV range for a full charge (it's lower for partial charges). Mine was down to 9.4 to 9.6 after a charge for 2 to 3 months. Did the dealer thing and they said to turn off the AC, lights, nav system etc. What I discovered is that the FAN must be off. I was turning on the fan then turning off the A/C with the A/C button for fresh air ventilation thinking that would stop the battery draw. I discovered it's the FAN BEING ON that created the high draw and low EV estimates. Even turning on the defroster turns on the fan. So now I get my estimate without any heater a/c systems going to ensure the fan is off, then I do whatever I want with the A/C now that I know the batteries are full up. It seemed weird to me that even the dealer had not turned off the fan and got the same "apparently low" charges that I got. The A/C is the system that draws the 207 ac volts to operate, but the fan being on (regardless of speed) is the thing the computer evidently uses to make it's estimated EV calculations. Good luck - Mine is back from 9.4 to 11.6 provided the fan is off.
    P.S. sit there and try different things to see what happens to the estimated EV range as you turn them on and off, the running lights, parking lights, headlights. high beams lights, radio, nav system, etc etc. the ONLY thing I found was the FAN!! The lights evidently and all the rest operate on the 12 volt system, though I thought the fan would too. If it does then the computer programing is using the fan to indicate the a/c is on, even when it is off according to the switch. ??? Luck.
    Read more: http://priuschat.com/threads/shrinking-mileage.113450/#ixzz23xeu8TR8
  6. Bill3888
    25
    Riverside, Ca
    Here's what I discovered on my own. see if it helps --After charging place car in READY and then look at the Estimated Miles for EV. Then push the OFF button for the heater /AC system to get the fan off. Watch the EV estimate when you do this and you'll see a jump of 1.0 to 1.4 miles in the EV range for a full charge (it's lower for partial charges). Mine was down to 9.4 to 9.6 after a charge for 2 to 3 months. Did the dealer thing and they said to turn off the AC, lights, nav system etc. What I discovered is that the FAN must be off. I was turning on the fan then turning off the A/C with the A/C button for fresh air ventilation thinking that would stop the battery draw. I discovered it's the FAN BEING ON that created the high draw and low EV estimates. Even turning on the defroster turns on the fan. So now I get my estimate without any heater a/c systems going to ensure the fan is off, then I do whatever I want with the A/C now that I know the batteries are full up. It seemed weird to me that even the dealer had not turned off the fan and got the same "apparently low" charges that I got. The A/C is the system that draws the 207 ac volts to operate, but the fan being on (regardless of speed) is the thing the computer evidently uses to make it's estimated EV calculations. Good luck - Mine is back from 9.4 to 11.6 provided the fan is off.
  7. Cherazi
    Cherazi New Member
    Bill,
    I have the same problem what was the outcome?
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    If you havent already done so, read through this thread. Its been explained by many people here.
    But to summarize, its just an estimate. Just like your "miles remaining" on your tank of gas or the "distance to empty" is just an estimate. Its based on your past/recent driving pattern/history. If you're truly concerned, you need to figure out if your maximum range on a full charge is decreasing. Get a full charge, find a long road with no stop signs or traffic lights and just drive. To my knowledge, no one has yet demonstrated any loss of range.
    Read more: http://priuschat.com/threads/ev-miles-estimate-after-full-charge-low.111396/page-8#ixzz2HjHe7PBb
  9. lensovet
    2,615
    496
    Burlington, NJ
    This is covered in our FAQ thread. Please read the explanation there, and welcome to PriusChat!
  10. bisco
    52,091
    anybody emailed social suze with there ev estimate problems lately?
    #170 bisco, Apr 17, 2014
    lensovet likes this.
  11. retired4999
    2,652
    627
    Eau Claire, Wi.
    Arn't you in the loop? :p
  12. bisco
    52,091
    nah, she's mad at me for asking her to read the helpful posts.
    retired4999 likes this.
  13. Rick Kissel
    Rick Kissel Junior Member
    2014 Prius Plug-in
    Intermittent Charging Failure: That is what I'm experiencing: Sometimes, when I connect the charge plug, I see the "charging" indicator by the plug, for about 20 seconds, then it goes Off, as though the charging has been completed; however, the "power" indicator on the cable indicates that the cable is powered and the dashboard display shows that the battery has not been charged at all!! The last time this happened, I had tried to charge the battery while still having 7 miles range on the EV display. I drove to the dealer (3 miles) on EV. The service manager tried to charge the battery, first with my charging cable (plugged into 120 VAC), and then with the dealer's 240 VAC charging station -- with the same result I have been having in both cases. I left the car for the dealer to check out (the dealer's shuttle took me home). Several hours later the dealer called to tell me that after I left, they had a mechanic check out the car. When the mechanic plugged in my charging cable, everything worked OK, and, after about 3 hours, the charging indicator went off, and the car showed full charge. I took the car home and everything was OK for a couple weeks, then it started happening again. BTW, the car is now 8 month old, and has 3,000 miles -- problems first appeared at 6 months and 2,750 miles).
    Has anyone had similar problems?
  14. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yes, I think there has been a few people with the battery charger in the car that has been defective. Have your dealer check that or maybe have them call Toyota.
    Hope this helps,, it is all I remember.
  15. bisco
    52,091
    that's all there is, a bunch of defective chargers.
  16. evfinder
    evfinder Member
    293
    72
    If you accidentally hit the charger button the car behaves exactly as you decribe
  17. bisco
    52,091
    that would really throw the dealers for a loop.
  18. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    What charger button are you talking about?
  19. bisco
    52,091
    the one on the dash?
  20. Jimbo69ny
    712
    107
    Ithaca, NY
    What charger button on the dash? Lol
