How many miles at full charge?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by SimiPrius, Mar 8, 2012.
  1. Godzuki
    Godzuki Active Member
    133
    114
    Bay Area, CA
    2015 Prius Plug-in
    13.3 - Last night I set the charge time to begin at 5:00am, by 7:45ish this morning, I went to go check on the car... The car was still charging so I hit the "Power" button to see if I could get an indication of how much time was left until full charge, and one I depressed the Power button, the car stopped charging...
    At this point, I didn't know if the car had completed charging, so I turned off the charge timer, uplugged the charger from the charge port, and then re-inserted the charger - the charge light lit for a few seconds and then turned off... At this point I guess I had a full charge, went inside, started the car up and the display indicated 13.3 miles of EV range...
    :high5:Oh what a feeling!:high5:
  2. dwtn
    dwtn New Member
    Update: Turns out if I just turn off A/C then I see 13.3 after charging - d'oh!
  3. calbear
    calbear Member
    180
    30
    SF Bay Area
    I turn off my A/C, Fan, DRLs, anything possible and I still have never seen above 11.3... :-(
  4. mrbigh
    3,686
    699
    Long Island, NY
    I'm facing the same inconvenience
  5. bisco
    52,074
    i can't believe you guys are still talking about ev range after all the informationa threads and posts about it.
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    maybe they're worried about their "EV masculinity":D
  7. bisco
    52,074
    mine is larger than yours.:whistle:
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    ok......then tell me why your avatar is a big question mark?:eek:
  9. bisco
    52,074
    because i'm not sure who i want to be when i grow up.
