2009 inverter coolant pump failure 51,300 miles
Discussion in 'Gen 2 Prius Main Forum' started by jklhill, Aug 16, 2012.
  1. jklhill
    jklhill Junior Member
    Just say'n. Covered under warranty.
    cwerdna and PriusCamper like this.
  2. kammssss
    kammssss Member
    287
    86
    SoCal
    It's probably the heat. I just installed a new water pump; it only lasted 70k. That is shocking because the original one lasted 145k.
  3. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Another gen2 iverter pump failure on 2008/9 with the updated pump luckily still under warranty for the OP. These pumps seem no better than the one's they replace.
  4. jklhill
    Yeah, it's been over 100 for a couple weeks now.
  5. bcarraher
    bcarraher Junior Member
    Austin
    Mine failed at 48k as well. Covered by warranty. Dealer said Central Texas heat probably to blame.
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Inverter coolant quickly gets contaminated with aluminum corrosion as evidenced by white film on cap especially from new. I Coolant see's extensive raw aluminum in heatsinks of Inverter. Aluminum is super corrosive. Take some of your I coolant out an look at it in clear glass and compare to fresh SLLC. Contaminated fluid very abrasive and hard on pump.
    Changed my I Coolant at 30K and no longer see white dusty film. Plus I installed half a bottle of this:
    Red Line Synthetic Oil - WaterWetter® Coolant Additives - WaterWetter®
    I also run a bottle in the ICE coolant.
    Excellent aluminum anti corrosion additive. Use it in all my cars for years. Greatly extends life of coolant and helps with coolant heat transfer. Rads looks brand new after years of use. Great product.
    snijd, Rokeby and nh7o like this.
  7. snijd
    snijd DIY or die
    243
    52
    PNW
    This is the first time I've seen this suggested as the cause of early pump demise, but it makes sense. Redesigned or not, with bearings running in coolant, this would trash them. BTW, Luscious Garage says the newer pumps are failing, just like the old ones.
    richard schumacher likes this.
  8. bcarraher
    Austin
    Recall just issued addresses this specific problem.
  9. snijd
    snijd DIY or die
    243
    52
    PNW
    Toyota's take seems to be that a winding wire is corroding, leading to pump failure. Not bearing failure, as I'd thought. Time will tell.
