pairing 2 iphones to bluetooth?
Discussion in 'Prius c Accessories and Modifications' started by davidkde, Aug 13, 2012.
  1. davidkde
    davidkde New Member
    Posted this in technical forum, but only 1 response that didn't work..
    Hello,
    I have 1 personal iphone 4s and 1 work iphone 4.
    Can someone tell me how to pair both phones onto the radio? I have a c2.
    When i go to BT pairing it asks me if i want to delete all devices (if i press NO, it doesn't do anything.) If I press YES, i can only pair one of the phones and the other one will say "make sure BT is on and device is in range" or something like that.
    I would like to pair both if possible (for safety reasons when driving and getting a phone call).
    Any help will be appreciated!
    thanks!!
  2. davidkde
    davidkde New Member
  3. oberkc
    oberkc Junior Member
    22
    Ohio
    My understanding is that you pair the second just like the first... put one in discoverable mode and search with the other. Just be aware that I don't believe you can pair a second (or third) device if the first is connected. Also, I don't believe you can use more than one at any point in time.
  4. Nall
    Nall New Member
    You can pair one at a time and have both in the stereo's memory, but you can only use one at a time. If you go to paired devices in the settings you can switch between them. You can't get calls or play music from both without doing this though, the car will reconnect with whichever phone was last connected when you start it up.
  5. Holly Ormseth
    Holly Ormseth New Member
    Hi !
    I have a similar problem. I can't connect multiple devices. However I can't even click on the "add new device" button, and I can click on the "delete" button for the already paired device- is there some way that I don't have privileges to do these things?
    The paired device is far out of range. I've tried restarting the system .
    Thanks!!
  6. B2FiNiTY
    B2FiNiTY Active Member
    979
    226
    Is your car in park and with the ebrake on while you are doing this?
    Do you get any error messages?
