Drivers leg room
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Big Dude, Aug 24, 2012.
  1. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    I have '08 Prius and the leg room driver's cockpit fit me fine. The 2010 not so much. Sometimes power seats give more room. Any BIG/Tall men out there with a PIP? How does it fit?
  2. simply_me
    simply_me New Member
    North Eastern USA
    I'm 6' and it fits me very well. with room to spare.
  3. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    6' 215 lbs and I fit fine.
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
    6'2" 250 lbs fits just fine! I like it.
  5. Biking Maniac
    Biking Maniac Five Prius – have not sold one yet!
    58
    Menomonie Wisconsin
    2001 Prius
    195 cm tall and all legs (94 cm inseam), I fit just fine but it seems more spacious in our ''05 and '06 I think.
  6. sdplugin
    sdplugin First Time Prius owner
    22
    San Diego
    6' 2" and it fits just fine, I'm quite comfortable.
  7. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    My PiP is the base model, so no power seat. But it seems to me to have more legroom than my '06 did (same seating as your '08). I'm 6' tall and fit just fine with the seat as far from the wheel as it will go, and the height adjusted as high as high as it will go. The back rest angle I keep somewhat back, as I have long arms. All things considered, I'm comfortable. You might wish to rent one for a few days before deciding. Good luck.
  8. chesleyn
    chesleyn Active Member
    596
    158
    Los Angeles
    6 ft, 180 lbs and fit great -- back seat included. That was the first place I checked.
  9. ultraturtle
    108
    81
    Peachtree City, GA
    6'3" and do not need to roll the seat anywhere near its rear limit to gain plenty of legroom. Unfortunately (as posted elsewhere in this forum) at the point of comforable legroom, the steering wheel is uncomfortably far forward. Perhaps you suffer the same tradeoff I do - rolling the seat forward enough for comfortable steering wheel access results in cramped legroom.
    Also, as has been posted ad-nauseum, without an airplane-size pillow for lumbar support, the seat is a torture rack for anyone over 6' 2". For what it's worth (after two bad purchases) I found a really good one that somehow seems to help alleviate both problems somewhat:
    Amazon.com: Sleep Innovations Gel Insert Travel Pillow: Home & Kitchen
  10. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    Thanks everyone. I'm 6'6' and "executive size" (the new PC word). I'll be in the showroom as soon as the 2013 models hit the mid-west.
  11. Biking Maniac
    58
    Menomonie Wisconsin
    2001 Prius
    There are several of us in Wisconsin with PIPs. If you care to send a private message we can figure out if any of us live close to you and let you check one out.
  12. extendmyseat
    extendmyseat New Member
    You may purchase seat extenders on PriusChat that will give you 4" of additional legroom. The seat extenders offer a simple DIY solution for taller drivers.
  13. extendmyseat
    I am 6'5" and there is a easy DIY solution for your Prius C, V and 3. You may purchase seat extenders that will give you up to 4" additional legroom. These are built for taller drivers by taller drivers.
  14. YYR123
    YYR123 Junior Member
    8'2" and I fit fine in my shoebox just in case anyone was wondering !!!! Hahahah
    2007 Prius - 140K - Green
