Satellite radio quality.
Discussion in 'Prius v Audio and Electronics' started by mcmoyer, Aug 21, 2012.
  1. mcmoyer
    mcmoyer Junior Member
    71
    Fort Worth, TX
    I've tried several times to listen to the XM/Sirius service without trying to cringe, but it's darn near impossible. It feels like I'm listening to an MP3 with a 64k bitrate. Is this normal? The bass is fine, the highs are ok, but the midrange just sounds horrible.
  2. rjparker
    10,483
    6,572
    Probably normal. They vary the bitrate according to the station. They sometimes gave the Classical station more bitrate than a rock station which got a lot more than a talk station. All stations are compressed and they apparently jammed more stations into the same overall bandwidth when they were granted a merger between XM and Sirius by the Bush administration. Sirius XM Radio - Wikipedia, the free encyclopedia It's easy to blame the radio and speaker system, but HD radio has good sound with the same hardware. Obviously not as good as an expensive aftermarket solution.
  3. n0na
    n0na Junior Member
    88
    WA
    I'd blame the car's audio system. My car had booming bass until I turned the bass as far down as it would go. Booming bass is probably the most obvious sign of a poor audio/speaker system. I doubt the Prius v3 audio system would allow you to hear any subtle differences in audio quality (due to compression or whatever) from an XM signal.
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I still find the Ipod into the HU sounds the best for me, best of all, I guarantee NO commercials, just tunes I like.
    Wow, a win,win!
  5. mcmoyer
    71
    Fort Worth, TX
    this is really bad sound. Sound from CD's or the iPod are fine (I've already turned the bass down a bit), but the voices coming through on XM sound like robots. It's also very noticeable at low levels where the bass wouldn't be an issue. I just double checked my wife's car - a Buick Enclave with the Bose system. It also demonstrates the same issue. So, I guess I just answered my own question, the XM signal really does suck ;)
  6. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    The signal has degraded, quite a bilt. I tried changing antennas to improve signal - no such luck. I may end up dumping XMSerius when renewal comes up.
    DBCassidy
  7. sURFNmADNESS
    sURFNmADNESS Prii Family
    199
    48
    Omaha, NE
    It might be possible you are in a market with a bad repeater. Call XM and report the issue. They use repeaters in larger metro areas (900+ now in USA per wiki) to counter tall buildings and hilly terrain where direct line of site is not always good. With my older XM radio, I had two bars which showed me the repeater signal and satellite signal strengths. I do not see that available on my v3.
    UPDATE: found this posting with list of cities which have XM repeaters deployed.
    xm411.com - What is and where are the Ground Repeaters?
  8. jtiptonca
    jtiptonca New Member
    Palm Springs, California
    I'm a musician...and I've never had a problem with my Sirius quality in all my other cars with it, nor do I have a problem with the signal in my now new XM radio. But, the stock speakers in the Prius leave MUCH to be desired. Project to replace the speakers and put in an amp/subwoofer is happening next month.
    I have heard that there has been some degradation of XM signal from time to time due to repeaters. Sirius does not use repeaters like XM does (a basic difference in the two products) so maybe it is a repeater problem in your area. Since both Toyota and GM both exclusively use XM radios it would be hard for you to compare the two.
  9. Gun owning Prius driver
    397
    78
    Downey, California (Los Angeles Area)
  10. n0na
    n0na Junior Member
    88
    WA
    National Public Radio:)
  11. Gun owning Prius driver
    397
    78
    Right on, so regular stations. Thought maybe it was something like talk radio.
  12. Patti Prius
    Patti Prius New Member
    We traded a 10 year old RAV4 with a Sirius owner installed unit that had very rare cutouts here in rural New Hampshire. We bought a Prius IV a month ago and the built in satellite radio (is it Sirius or XM?) cuts out often driving the same roads that the RAV4 had no problem with. The dealer has no clue and hasn't answered my question where the antenna is.
    My wife just read in the Owner's Manual that we have an XM radio. So that could explain the difference in reception compared to the previous Sirius unit.
    With the current XM reception we will not be paying for service after our 90 free trial expires.
  13. Bigham
    Bigham Junior Member
    Has anyone had a real problem with dead spots and dropouts with the XM radio? We have been using add on units in our old cars for a long time now and they have excellent reception, and there are a very few spots where we know to expect dropout.
    Now with the built in unit in the Prius v, it happens all the time to the point it is annoying to listen because of the dropouts. When we lose signal there is a hiss until the music comes back. I was trying to take a nap while my wife was driving and the dropouts kept waking me up! Very annoying.
    Any idea how to improve the reception?
  14. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Sirius' technology is better than XM. Sirius does have ground repeaters in major metro areas (DogstarRadio.com Sirius Radio Satellite and Repeater Map), but XM is more terrestrial than space and the quality is much lower.
    I use a Sirius receiver into the AUX jack on my Prius and it sounds great. The popular channels like Hits 1, 80's, 90's, 2000's have much higher bitrates than other channels. The talk/comedy/news channels are the worst. The bitrates are variable. We have XM in the Lexus and it actually sounds pretty good on that radio system. But I have heard XM in other vehicles including the Toyota trim and it definitely sounds worse than Sirius.
  15. rjparker
    10,483
    6,572
    I have no issues except occasionally underpasses. Have Toyota fix it.
  16. Worldtraveler
    Worldtraveler New Member
    I have Sirius in my other car (2008 Mercedes S550) and in my new 2013 Prius 3. The Mercedes has a top-notch audio system that sounds great on the local classical FM station, on Audio CDs, and on MP3s. But I found I could not stand the Sirius audio on the classical stations. I believe the sound is balanced for ear buds. The bass booms and the treble is shrill. Trying to compensate with the tone controls is inadequate.
    I find exactly the same thing with the Prius, although the audio range is a little more restricted to start with. I let the one-year trial lapse with the Mercedes, and will let the 60-day trial lapse with the Prius.
  17. rjparker
    10,483
    6,572
    XM plays with the bitrate based on the station. Plus the audio system itself is a factor. XM sounded better before their merger with Sirius.
  18. sURFNmADNESS
    199
    48
    Omaha, NE
  19. JasonW
    JasonW Junior Member
    30
    Texas : Austin Area
    Sounds horrible on mine as well. As you said, like a really low bit rate mp3. What's interesting, is that I recently rented a different make/model car that uses Sirius, and it sounded quite good. I wonder Sirius broadcasts at a higher bit rate? (I know they are the same company now, but they use slightly different technologies)
    I want to like XM, I really do. But most of the stations just sound soooo bad. Tinny and warbly digital compression sound, with overly heavy bass as though that compensates for it.
    Pandora through my phone, or spotify sounds infinitely better. I tend to just use that, or listen to my own music.
  20. Bigham
    Toyota is supposed to replace our radio. Sirius told me the radio was bad because of dropouts and it would not take an upgrade flash. Two times back at e dealership and still no radio. Keep forgetting to order it for us.
