Color Match?
Discussion in 'Gen 3 Prius Main Forum' started by Econ, Aug 15, 2012.
  1. My paint matches all over the car.
    9 vote(s)
    90.0%
  2. I have the same issue.
    1 vote(s)
    10.0%
  3. No problems
    1 vote(s)
    10.0%
Multiple votes are allowed.
  1. Econ
    Econ Member
    329
    26
    East of the Berkshires - MA
    I have a black lll Five. The plastic parts ie front and rear bumpers do not match in color to the metal body paint. I has been that way since new and I get crazed when I see it so obvious. A few of my buddies have mentioned it but I tell them that they are seeing things :)
    I recall on member here had mentioned this paint color match stuff but I was not able to follow-up.
  2. priuscritter
    priuscritter I am the Stig.
    1,525
    199
    Indiana
    You are correct. the paint does not match between plastic and metal parts. it's most noticeable in the sun. It's pretty crappy I think but that's the way it is.
  3. bear4
    bear4 Junior Member
    68
    FL
    I have the same issue with my super white 2010 corolla. However, my Blizzard Pearl Prius has pretty good match. I guess it depends on the assembly plant?
  4. Timw
    Timw Junior Member
    55
    Southern, PA
    I have a 2011 II Sandy Beach and it matches!
  5. JBoat
    JBoat New Member
    37
    Denver, CO
    Odd. I have a 2010 with Winter Grey Metallic exterior, and Dark Grey interior. Pretty much everything blends well with everything else, inside and out.
  6. FractionalDerivative
    Bumpers shouldn't be painted in the first place. Or at least there should be a lower trim that is not painted.
  7. priuscritter
    1,525
    199
    Indiana
    all i know is my blue is very noticeable, and there was a thread back in the day about it. different theories were the difference in materials (plastic vs. metal) and maybe even using a different paint on the plastic so it flexes more.
  8. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    Mine matches perfectly, even in the sun. I've clay-bar'ed, polished and waxed the whole vehicle, and that shouldn't help in principle but it might.
  9. priuscritter
    1,525
    199
    Indiana
    got a picture tonight. now, it doesn't always look this different. it does at certain angles when the sun hits it. in the shade, you can't really tell much. but you'll see that there is definitely a difference.
