Losing Time
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by iplug, Aug 30, 2012.
  1. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Mine loses about a minute a month. Oh well.
  2. Jimbo69ny
    Jimbo69ny Active Member
    712
    107
    Ithaca, NY
    Its not the clock. This car is ahead of its time. HAHA!
    iplug likes this.
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    You shuda, could have, would have gota PIP Advanced, doesn't it come with an atomic clock?
  4. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Nice, let's go with that. I was also thinking, the physics inclined among us could perhaps explain a different "ahead of its time" - the discrepancy using Special Relativity. But usually this means we are talking about traveling at very high speeds, an attribute not typically ascribed to our beloved Prii.
  5. bisco
    51,835
    :LOL:
    Andyprius # 1 likes this.
  6. stu lb
    stu lb Junior Member
    59
    Long Beach
    On my PIP, the clock isn't nearly as accurate as the one on my former 2005 Prius--it was very accurate for years, especially compared to the current PIP clock, which loses time much more quickly.
  7. Mine is a year out of sync. I keep showing up for appointments a year late.
  8. tiggerntatie
    tiggerntatie New Member
    17
    New Hampshire
    Yes, that is what I'm seeing too. It is extremely likely that the timing is governed by a quartz crystal oscillator, but the tolerance on crystal could easily be as bad as 20 ppm or more, which would give rise to this sort of error. Perhaps Toyota tried to save a few pennies by using a looser spec on the oscillator.
    Do Toyota engineers read Priuschat?
  9. bisco
    51,835
    i double checked mine. it's one minute slow and may have been that way when i got it. i wonder why they're not all the same?
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    mine's 30seconds off. been awhile since I set it to my watch. maybe a month?
