2002 Don't know who to trust
Discussion in 'Generation 1 Prius Discussion' started by Pristina, Aug 28, 2012.
  1. Pristina
    Pristina Junior Member
    77
    Tampa, FL
    2002 Prius
    I
    I am a new 2002 prius owner, just bought less than a month ago. It has 135000 miles on it and less than a week after I bought it warning lights came on: Picture of a battery, ps, and car (!). I have gotten a new 12v, and a new inverter pump by the recommendation of the dealer. Turns out they decided that I needed a new hybrid battery for 2600 after the pump didn't solve the problem. Here is my issue: I don't trust them anymore because 2 service technicians tried to scare me purely about corrosion on the battery! The other day, my car didn't shut off but wouldn't accelerate when I was going 45 mph on the road. I pulled over and stopped and it restarted but I know there is a problem.
    I have tried to get more information from them since then and they don't call me back. The codes they pulled were p3000 and p3009. I went to someone who repairs prius battery but had never worked on a gen 1. Since most things in the main battery are fairly similiar in newer models though greatly simplified, it looked familiar to him for the most part.
    He tested all the cells and they were all sufficient voltage. However, the harness inside the battery box was partially burnt. He said I would need to find that part. I found one in California but when I called back to order it and asked if the guy had any guarantee it worked, he made me uncomfortable but I was still going to give it a shot. He asked if he could call back and never did and I have not been able to get ahold of him. He told me that the harness was burnt for a reason and there were prob some exploded cells that would still test and look fine from the front and show a problem only from the sides.
    Help!!! I have aldready invested near 6000 into this car in less than a month. I can't afford a new batt at 2600 and cant find anyone to trust period since the dealership has been so rude! As far as I know there has not been a lead to solve the problem since I heard the ECU wouldn't even be repalaced with a new battery.
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved to the gen 1 forum from the Prius c forum.
  3. chaotic
    chaotic Junior Member
    Murrieta, California
    2001 Prius
    I
    wow.. tons of problems... but better the way mr wilson wrote it
    There comes a time when a car has reached the end of its useful life but this is driven by the owner's requirements:
    • payload - a family grows and a small car no longer meets the needs or a new home owner needs to transport house 'stuff.'
    • reliability - unplanned repairs impact a fixed budget in a way that is not acceptable
    • performance - the existing vehicle performance has been eclipsed by newer vehicles
    Only the owner can decide when the car has reached the end of its design life (or an accident takes it away.) You've had a chance to understand what the sedan style, Prius can do, and how well a used Prius has worked out. So you have options:
    1. Used NHW11 - what you already have. The model years are 2001-03.
    2. Used NHW20 - the next generation 1.5L Prius hatchback has significant improvements over the NHW11. Model years are 2004-09.
    3. Used ZVW30 - the current generation 1.8L Prius hatchback further important improvements over the NHW20. Model years are 2010-2011.
    4. New ZVW30 - the 2012 Prius has the first upgrades to the ZVW30 and is likely to have fixed a number of small, early problems. Model years 2012-current.
    5. New Prius v - the station wagon sized, Prius, with similar EPA mileage rating of the NHW11 but huge increase in payload. Model years 2012-current.
    6. New Prius c - the 1.5L Prius with identical payload to the NHW11 but significantly improved performance. Model years 2012-current.
    You know your financial position and vehicle requirements . . . I for one will one will not try to second-guess what works best for you. But you have one big advantage, you know the Prius is a real fuel saver and generally works. But your used, NHW11 having reached a decade of service, you have to decide when it is time to become someone else's project car or 'parts.'
    GOOD LUCK!
    Read more: http://priuschat.com/threads/reviving-my-2001-prius.113943/#ixzz24zyE3w24
    i have p3000 and p3009 and i recently had the battery replaced in reviving my 2001 prius... and i know that it takes a lot in diagnosing the problem... depending on where you are i would look to see an experienced tech in your area... i know NOTHING about PRIUS (except that i like my prius) ... but i know how to read a service manual and pretty handy with tools... i ask a lot of questions here and use the search bar a lot as well...i think you have to make a choice at this time to keep the car or like mr wilson said... become someone else's project car.. dont think you are alone... the techs on this site... are amazing and help with as much as they can... plus just like me... want to see more prius on the road... even my ugly one...
    *ever notice that prius owners tend to wave and smile at each other*... weird...
    cwerdna likes this.
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    I'm willing to try to help you if I can. If you're interested, reply to these.
    Does the car still run?
    Do you have any codes/warning lights right now?
    Have they been reset and if so, do they come right back?
    We can get your car fixed if you're patient and stick with it.
  5. Pristina
    77
    Tampa, FL
    2002 Prius
    I
    Thank you so much! I feel a little less helpless...
    To answer your questions, yes it does run, the codes pulled by Toyota were p-3000 and p-3009 (which someone here has since mentioned is actually a transmission issue...I hope not) and when the codes were reset the first few times they came right back, this last reset was after a battery cleaning and it took at least a few days to come back. Any help is greatly appreciated, I would love to keep this car if I can make it reliable again!
  6. Pristina
    77
    Tampa, FL
    2002 Prius
    I
    Thank you for the advice. Not sure if I can swing it depending ion the quantity of repairs that I find out it needs cumulatively. But I would certainly love to keep the car if I can!!! I really fell in love with Prius before I ever even owned one.
    Reside in Tampa, FL.
  7. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Pristina likes this.
  8. bwilson4web
    16,535
    You might want to read this thread:
    P3009 battery Frankenstein project | PriusChat
    You might want consider ReInvolt who sells a replacement, refurbished traction battery pack for about $1,700 (a couple of years ago.) It is a heavy part taking two people to swap it safely. However, the newer modules in their pack are much better with stronger terminals. But before spending that kind of money, it makes sense to verify there are no other problems.
    The Scangauge II costs about $150 and has the ability to add software, XGAUGE definitions to read out specific diagnostics and even the voltages of the module-pairs in the traction battery. But we can also use it to check the other major Prius systems. It changes "shot gunning" a solution into something more precise.
    Let me suggest using the search function and reading up on the P3009 code.
  9. bwilson4web
    16,535
    OWCH! That was probably about $500 for a bad fix!
    Which battery, the 12V?
    There is a known weakness in the accelerator called the "big hand" syndrome. This symptom is consistent with the car going into a 'safe home' mode. It is awkward and repairable but not a fun experience.
    Did he take out the back seat to work on the traction battery? This does not sound right.
    If this is the traction battery, I would expect the car not to run at all.
    Is the car still running?
  10. Pristina
    77
    Tampa, FL
    2002 Prius
    I
    Answering your questions in order:
    I agree with you that was probably unnecessry and their lack of effort to pull open the traction battery.
    No, the traction battery, but I also did have the 12 volt replaced first thing.
    Who would be able to do the "big hand" repair?
    He did take out the back seat...I am wondering if water from a leaky seal has made its way in at a point to the harness/ECU joint because there is a leaky seal in that rear window (theory only).
    That is great news!!
    Thank you soooo much for taking the time to answer questions. Also, looked into reinvolt, only fear is that there is actually a transmission problem as well which would make me sell the car instead of paying thousands over its worth.
  11. Pristina
    77
    Tampa, FL
    2002 Prius
    I
  12. Patrick Wong
    18,210
    6,517
    1. How about posting photos of the battery bus bars and the burnt wires.
    2. It is possible to purchase replacement bus bars and the voltage sense wire cabling from a Toyota dealer parts department.
    3. Can the car be driven in its current condition?
    Your story indicates why it is not a wonderful idea to buy an older Prius if you don't have four-digit amounts set aside for significant repairs. It is reasonable to expect that some Prius offered for sale have a problem prompting the sale.
  13. usnavystgc
    3,159
    990
    Tucson, AZ
    Above is an exploded diagram of the HV Battery for your Prius. Can you tell us which cable is partially burnt? Is it # 16? If so, I would start by replacing just that part.
    Here is a link to the part #'s and their names along with the price of each. 2002 Toyota Prius Parts - Genuine Toyota Parts
    Part 16 is less than $30. I have to warn you about me so you can decide how much attention to pay me. I am very cheap and I always look for the most inexpensive way to accomplish something. I avoid dealers whenever possible. Cheap usually means you have to do the work and, you are likely to make mistakes. Additionally, I am not an expert but, I have been working on cars (and anything mechanical) for over 30 years. I am not afraid to do anything or work on anything. I also have lots of tools so, If I make improper assumptions, forgive me.
    With that said, here are my thoughts. I like to start out cheap. You know the harness (whichever one it is) is burnt and definitely needs replaced. It is cheap and fairly easy to replace. Do that first. If that doesn't fix your problem, I would then change the tranny fluid (about $50 to DIY). If that doesn't fix it (there is a low probability that it will), the problem has to be isolated because so many different things can cause this fault (p3009).
    More info to consider. If all the cells are of sufficient voltage, your battery may be good (and probably is). Some techs at the dealership are good but they have flow charts they go by to repair things (usually assemblies are replaced). These techs are just simply going by their book (as they're supposed to).
    Other questions:
    1) How does the car drive?
    2) Are there any driveability problems at all (no driveability problems "usually" means the tranny is good)?
    3) Does the car still get good fuel economy?
    4) Does the battery charge and discharge (use the "Energy" screen to determine this) like it used to b4 u had this problem?
    If you haven't already, read this and perform the test indicated in para. 6.
    Luscious Garage | Blog | Toyota Hybrids P3009: High Voltage Leak Detected, internal to battery
    Hang in there, be patient. Hopefully we can get this fixed on the cheap :).
  14. bwilson4web
    16,535
    A running Prius is much better than the alternative. The next tests are things that do not require an Onboard Diagnostic Bus (OBD) scanner:
    • Do you hear a speed related 'rumble' even when coasting in "N" - this is the sound of a shorted, MG2, a powerful motor in the transmission. MG2 has a fixed gear ratio to the wheels and if it develops a short, it will create a 'rumble' whose frequency changes with speed. The only know repairs: (1) replace the old, 45 lb, stator, or (2) replace the transmission from a salvage. Either repair takes "heavy lifting" but we're talking about $1,000-$1,500 depending upon which not-Toyota shop is used. We're talking a couple of months or less before it fails hard.
    • Do you hear the traction battery fan running after 10 minutes or so in the first drive - this indicates one or more modules has failed and is overheating the traction battery. Eventually, enough modules will fail and the car won't run. But we're talking up to a couple of months or less. The P3009 and earlier traction battery reports suggests there is a problem.
    Now you'll eventually have to decide if you are going to keep or dispose of the car. Having a good OBD scanner allows you to see what the shop sees (or should see) to understand what is going on. At $150, the Scangauge II is what I recommend for folks who want a usable scanner that has XGAUGE capability to read out Prius specific metrics. It can also be used in other cars but the XGAUGE is about as complex as composing a cell phone text message. Just a thought but we can chat about this more later.
    Anyway, try the first two tests and let us know what you find.
    Thanks,
  15. Pristina
    77
    Tampa, FL
    2002 Prius
    I
    I am assuming to take photos of those parts I will have to open the battery, right? Please be aware that you are talking to someone who knows very little about the actual hands on mechanics of cars. I have seen the battery inside but I do not know what bus bars are. I will try to post photos once I know what things are if you can describe them in lay terms.
    It can be driven. I have only had one time where it stopped accelerating...Bob Wilson referred to it as Big Hand syndrome I think? Yes, I wish I had come across this site before purchasing it to be made aware of that.
  16. Patrick Wong
    18,210
    6,517
    OK, if the battery has been reassembled and you don't already have photos, I don't expect you to take the cover off just to get photos.
    If the car can be driven and the only problem is that you see warning lights, I suggest that you consider changing the transaxle ATF as previously suggested, as that might help DTC P3009 (which is a high voltage ground fault), if the fault is in the transaxle. However, the ground fault could be caused by any component exposed to high voltage including the traction battery, the traction battery ECU, the high voltage battery cables, the inverter, and the transaxle.
    Other than that ATF fluid change, I think you should just drive the car and ignore the warning lights for now, until you start to notice driveabililty symptoms.
    DTC P3000 implies a problem with the traction battery ECU but that is likely due to the voltage sense wires being impaired by the burnt wiring.
    Once you start to have more severe problems, then it would be time to open up the battery again, replace the burnt wiring, clean corrosion off the battery cells, and reassemble hoping for the best. If that doesn't help then you may need a replacement traction battery at minimum.
    Regarding the "big hand" syndrome and lack of acceleration, this is caused by the accelerator pedal sensor which contains a couple of variable resistors. Voltage flowing through those resistors report accelerator pedal depression to the engine ECU. Over time the resistor elements get a bit corroded which causes intermittent operation.
    The cure is to replace the pedal sensor. You might obtain short term relief by depressing the pedal over its full travel several times, in an effort to clean the corrosion off.
  17. Pristina
    77
    Tampa, FL
    2002 Prius
    I
    I am assuming to take photos of those parts I will have to open the battery, right? Please be aware that you are talking to someone who knows very little about the actual hands on mechanics of cars. I have seen the battery inside but I do not know what bus bars are. I will try to post photos once I know what It can be driven. I have only had one time where it stopped accelerating...Bob Wilson referred to it as Big Hand syndrome I think? Yes, I wish I had come across this site before purchasing it to be made aware of that.
    Thank you so much for your help. Is changing the transaxle ATF something I can do myself? I hope it is not dealer mandatory but if it is I will just go to a different dealer.
  18. Patrick Wong
    18,210
    6,517
    Yes, the transaxle ATF drain and replace is a simple process if you have the correct tools and some prior experience working on cars. You need 5 quarts of Toyota ATF T-IV and ideally should replace the gaskets for the drain and fill plugs. This is available at your Toyota dealer's parts counter.
    The front of the car needs to be raised on jackstands.
    The transaxle ATF drain plug is on the bottom of the transaxle, within the black transaxle drain pan. There is also another drain plug for the inverter/transaxle coolant located on the transaxle case nearer to the engine, leave that one alone.
    The transaxle ATF fill plug is on the side of the transaxle facing the engine radiator. Make sure you can remove the fill plug before you drain the ATF.
    You will need a 24 mm socket (or 15/16") to remove the fill plug. Tightening torque is 29 ft.-lb. I sold my Classic a few years ago and have forgotten the socket size needed to remove the drain plug, it might be 19 mm.
    If you wish to do a complete job getting rid of debris in the transaxle, you should also remove the transaxle drain pan, clean off the magnet sitting on the bottom of the pan, and wipe the pan bottom to get rid of all of the dirt there. In that case you will also need a transaxle drain pan gasket.
    You will need solvent and lots of paper towels to facilitate the drain pan cleaning process. I would use paint thinner or kerosene. Make sure the pan is dry before it is reinstalled and that there is no towel lint caught in the pan.
    The bolts securing the drain pan need blue Loctite to be applied on the threads, and the tightening torque is 5-6 ft.-lb. Do not strip the threads in the transaxle case.
    After the drain pan is reinstalled and the drain plug is in place, you need to fill the new ATF. The easiest way to do that is to use a funnel with a 3 ft long hose. Place the funnel near the inverter and snake the hose opening down to the fill hole. Then slowly pour the ATF into the funnel. Do this carefully so that you don't end up with ATF all over the inverter and transaxle.
    There are several posts about how to do this, but note that the 2G process is a bit different from Classic because 2G uses 4 quarts of Toyota ATF WS and does not have a transaxle drain pan.
    cwerdna and chaotic like this.
  19. ChapmanF
    19,020
    I still have mine, and it's 24mm (same as the fill plug). :) The tightening torque is different though: 29 ft-lb is just for the fill plug, use 36 ft-lb for the drain. Both plugs take a gasket part number 90430-18008 (if you keep the car long enough to change the transaxle coolant someday also, that drain plug uses the same gasket part number too).
    I liked all of usnavystg's suggestions for battery repair on the cheap. I wouldn't change much, but I would at least mention that some precautions are in order (you mentioned being relatively inexperienced with mechanical work, but didn't indicate your electrical experience). There are two things worth knowing:
    • The battery is a stack of modules adding up to about 300 volts (when fully charged) from the first to the last, more than twice the voltage in your house wiring. Electric shock, burns, and fire are all possible if you are not careful.
    • The reason parts may corrode is that some of the battery electrolyte may leak out. That stuff is potassium hydroxide, highly alkaline, corrosive not only to metal but also to skin and eyes.
    Now, I'm not the sort of person to yell DANGER DANGER SCARY THINGS RUN AWAY!!! Breathe. :) You can learn to work carefully and safely on this stuff. I just didn't want this thread to fill up with casual instructions about "just pop the battery open and do this and do this..." assuming that you already know.
    If you search the forum for threads on the hv battery sealing service campaign, you'll probably find a PDF file of Toyota's full instructions to dealers on how to do that repair. It's a good way to get familiar with the safety precautions they teach their techs to use.
    Toyota's instructions might be leaning toward overcautious; for example, in a car that was known not to be in any accident and was not showing any high-voltage leak codes, an experienced tech might be comfortable working in the battery without the electrical gloves, as long as the interlock plug was pulled out and safely in her pocket. With the plug out there's no more than 150 volts between any two points on the battery and if there are no leak codes then you know what points those are. Leak codes (which you have) would suggest being more careful.
    "Work slowly and carefully and think before each move" is probably enough advice if you have the electrical understanding to know what to be thinking about. Otherwise, it would probably be good to study the safety steps in the Toyota pdf, and follow them closely. If you'd rather not go gloveless, one place you can buy them online is called Corvib.
    Happy hacking,
    -Chap
  20. Pristina
    77
    Tampa, FL
    2002 Prius
    I
    Thank you, I will have to do some checking around to see if I can use some supplies, and surely I will have to look up some diagrams. This weekend I will have some time off work so will be in touch with questions as I can act on things.
