transaxle disengaging & hybrid system & ABS warning lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by debely, Jul 11, 2012.
  1. debely
    debely New Member
    Gluckstadt, MS
    okay - see how to do that now. slid it - no change. what next??
  2. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Disconnect the 12volt battery for a few minutes to clear the system, reconnect and try again.
  3. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    This is a good idea, but, can you check the 12V battery voltage first? In case you didn't already know, you can do this with the MFD.
  4. Britprius
    5,194
    1,921
    If the link is in correctly now, in accessory mode the battery should about read 12v +or- when you go into ready mode it should read 14v +or-
  5. debely
    debely New Member
    Gluckstadt, MS
    Yall please stay with me!!!! It cranked!!! yea!!!! and all the red lights on the dash went away except for the triangle with the exclamation point in it. I will try to post some pictures.... this was when it would not crank just after we installed both batteries IMG_0181[1].JPG IMG_0181[1].JPG IMG_0181[1].JPG IMG_0181[1].JPG
  6. Avi's Advanced Automotive
    776
    363
    The triangle could be on because the door is open.
  7. Britprius
    5,194
    1,921
    Congratulations, sometimes it is the small detail that holds things up.
    John.
  8. debely
    debely New Member
    Gluckstadt, MS
    this is after I did the switch link thing and it cranked but was unsmooth in this engine sound. at first I could see the arrows point toward the battery bars then it didnt have any arrows pointing anywhere.. IMG_0185[1].JPG
  9. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Can you drive it?
  10. debely
    debely New Member
    Gluckstadt, MS
    the door was closed tho. so what else should I check? Can I drive it? and what does the red car mean that is on the computer display as in my post #25? is the same message and the triangle?
    anyway I let it idle a bit and kept the gas motor running. the battery bars dropped to two red ones but when i quit letting it idle the bars were 3 blue
  11. debely
    debely New Member
    Gluckstadt, MS
    all I did was put it in drive and move up a couple feet then reverse a couple of feet.
  12. Britprius
    5,194
    1,921
    The display looks normal for a battery with a charge of about 45% take the car for a short run to see how it behaves.
  13. debely
    debely New Member
    Gluckstadt, MS
    I don't know where to read that. I know sad, but I just have always got in and driven!!! where should I look at the volt reading?
  14. debely
    debely New Member
    Gluckstadt, MS
    okay be back shortly!!
  15. debely
    debely New Member
    Gluckstadt, MS
    but first, doesnt the red triangle mean the brakes (transaxle) are not going to function?
  16. Britprius
    5,194
    1,921
    For the moment do not bother with the 12v measurement. Try the car on a short run, the HV battery appears to be charging OK (bars going blue).
  17. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Take it for a short drive to charge the battery.
    If you want to let it idle make sure the the car is in "P" (so that it can charge the battery).
    If you are not confident to drive it at the moment you can try "force charging" the battery. Do this by placing it in "D" and placing one foot firmly on the brake and the other gently increasing the pressure on the accelerator until the engine revs at about 1500 - 1800 rpm and arrows are shown charging the battery. Take it up to about about 5 or 6 blue bars. If all this is working properly then by all means take it for a short drive.
  18. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Drive it on a quite street and test those things. Yes be careful, but you need to test to find out. Remember that you always have the park-brake as a direct mechanical backup.
    Some lights might not go out until after it's been driven for a while.
  19. debely
    debely New Member
    Gluckstadt, MS
    okay! i will drive it - yikes!!!
  20. Britprius
    5,194
    1,921
    Is the tail gate shut properly this can cause that red light.
