2007 Toyota Camry Hybrid Pictures
Discussion in 'Other Cars' started by Tideland Prius, Jan 9, 2006.
  1. Tideland Prius
    16,548
    Here are some pictures from the pressroom
    [attachmentid=1740]
    [attachmentid=1741]
    [attachmentid=1742]
    [attachmentid=1743]
    [attachmentid=1744]
    [attachmentid=1745]
    [attachmentid=1746]
    If you think the 06 Prius screen is cool, looks like they updated it again for the Camry with 1 min bars, distance to empty and a Best MPG readout.
    [attachmentid=1747]
    [attachmentid=1750]
    Camry Hybrids are distinguished by the HYBRID emblem at the side, HSD badge at the back as well as an L-shaped clear section on the rear taillights and a satin finished grille at the front.
  2. Jack 06
    Jack 06 New Member
    2,556
    Winters, CA: Prius capital of US. 30 miles W of S
    Interesting.
    1. They're allowing publicity material to show a reading of 25.6 MPG. If the car's EPAs are 43/37, why?
    2. Instead of the MPG scale ranging 0-"99" (infinity), this display stops it at 60---which could also double as infinity, huh?
  3. MNPrius
    MNPrius New Member
    177
    Minneapolis
    Personally I like the 5 minute bars - the one minute bars look "busy". But perhaps you would adjust.
  4. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    Good point Jack. Also, does the screen only go to 60 MPG rather than 100?
    With the empty spaces, there was clearly some idling going on.
  5. Danny
    Danny Admin/Founder
    7,093
    2,120
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Man, that is a pretty car. Well done, Toyota. Well done.
  6. LaughingMan
    LaughingMan Active Member
    1,386
    Marlborough, MA
    it still goes up to 99.9 MPG i believe. On cars like the Highlander and the RX400h, they have a similar screen that is more scaled to the mileages that are expected. Basically, the expected average MPG is centered on the screen. For the Prius, that's 50, and for the other HSD vehicles, about 30.
  7. Potential Buyer
    Potential Buyer New Member
    287
    Thanks for those pictures; I'd never seen those particular ones before.
    Look carefully; there's a blue "EV mode" bar below the 60 mark. When the engine is off, the needle will be in this blue area. That's a great idea since the current method makes it look like the car's getting 100 mpg when it's really just infinite.
    Well specifically those empty areas are where the car wasn't moving but wasn't using any gas either. Zero miles divided by zero gallons = 0/0 which is not a number and has no effect on average mileage.
  8. TonyPSchaefer
    14,816
    2,500
    66
    Haha, PB. I read your follow-up and realized that I actually used the archiac term "idling." Geez, how Priustoric of me. :)
