Disable Backup Beep on 2012 Prius Instructions
Discussion in 'Gen 3 Prius Accessories and Modifications' started by pghjerry, Jun 3, 2012.
  1. pghjerry
    pghjerry '24 Prius Limited
    58
    Las Vegas, NV, USA
    2024 Prius
    I've done it on my car, but had a few guys ask how I did it, so here we go:
    First you need the ScanGaugeII, you can order it from the PriusChat Shop and even straight from scangauge.com.
    Now connect it to your car's ODBII Port and follow the instructions below:
    Start Car (So its in Ready)
    Press Red Button (on ScanGaugeII)
    Press More
    Press More
    Press the > to More
    Press Edit
    On 00, Press Edit
    Enter 07C03BAC40 for TXD
    Enter 047B15AC0000 for RXF
    Enter 2008 for RXD
    Enter 000100010000 for MTH
    Enter RBS for Name
    Press OK
    Press Save
    Press Exit
    Press the Red Button
    Choose Gauge
    Now Press any of the White Buttons until you see RBS
    It should say 00ACRBS now
    And your done, no Backup Beeping
    And use the same instructions for any other codes you may want to read, or modify.
    Hopefully that helps those who were a bit confused.
    onlinemissy, ciclista and wotcher like this.
  2. pghjerry
    58
    Las Vegas, NV, USA
    2024 Prius
    onlinemissy likes this.
  3. eldiablo
    eldiablo New Member
    Thank You, this worked great. I bought the scangaugeII and it did the trick, great product to have!
  4. Andrax
    Andrax Junior Member
    Keep waiting for it to go on sale. I'm on my tablet so I didn't look at the full code list yet, but am guessing you can also modify the seatbelt alarm and set driver door to unlock the entire car?
  5. zebelkhan
    zebelkhan Member in good standing
    165
    Morgan Hill, CA
    If you cannot afford scan guage, you can still do it yourself using much cheaper scanners. I used a Elmscan5 scanner and my laptop using the program written by JerryLaz on post #175 of below thread to disable the beeps on my 2012 Prius. Once loaded, program simply asks you if you want them on or off, and you click on what you want! That simple.
    http://priuschat.com/forums/gen-iii...m/62494-2010-help-disabling-reverse-beep.html
    onlinemissy and CivicSky like this.
  6. Andrax
    Its not an affordability test, just harder to justify a $150 tool that I really only want to use to turn off the beeps. I very much appreciate your post about the other tool, found for 25, which will accomplish the same thing! Thank you!
  7. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    +1 for the Elmscan5 tool purchased from Amazon. Very simple to use with the download mentioned above.
  8. widrace
    widrace Junior Member
    Is all you want to do is disable the beeping noise inside the car when you put it in reverse? I just purchased a new Pruis 3 and asked them at the dealer to disable it for me. Took 5 minutes and no charge.
  9. Andrax
    Dealers will certainly do it for you if you buy a brand new prius from them, if you buy a used gen 3 Prius, private party, you are SOL in most cases.
  10. chinito77
    chinito77 Member
    84
    35
    Yamaguchi, Japan
    I bought my Prius from another Toyota dealer and they wanted to charge me $75 but my local one did it for no charge...go figure!
  11. markabele
    5,084
    1,782
    Nebraska
    You can do it with the Torque app super easy...that along with seat belt beeps.
  12. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    Really!? Where is the info on that??
  13. markabele
    5,084
    1,782
    Nebraska
    Just one of the stats just like anything else you would want to bring up on the screen.
