Master Warning sign lit up when switching the car off.
Discussion in 'Gen 3 Prius Technical Discussion' started by Dileepa Jayakody, Sep 8, 2012.
  1. Dileepa Jayakody
    Dileepa Jayakody New Member
    Hi All,
    I got a 2010 Prius. I noticed that when I turn the car OFF , the master warning sign (yellow triangle with an exclamation mark) and a message in Japanese (which I cannot read) appear for a few seconds.
    I don't see the warning when switching the car ON, or while driving. I experienced this frequently when switching the power OFF.
    Anyone has an idea why this happens?
    Thanks,
    Dileepa
  2. 50324prius
    50324prius Junior Member
    39
    iowa
  3. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Did you open a door before shutting it off?
  4. Dileepa Jayakody
    Hi guys,
    Thanks for your replies.
    David, no I didn't open a door before shutting it off. I will try to find out why it happens and let you guys know.
    If anyone else experience the same as I do, please reply to this thread.
    Thanks,
    Dileepa
