Steering wheel control button issue
Discussion in 'Gen 2 Prius Audio and Electronics' started by priusgto, Sep 5, 2012.
  1. priusgto
    priusgto Active Member
    194
    231
    Northern Arizona
    Hello,
    My 05 has a problem with the recirculate and defrost buttons on the wheel. The recirculate button will sometimes toggle the MFD between the consumption screen and the energy monitor screen like the info button does and won't change the recirculate light on the dash at all. Sometimes it will do nothing, and other times it works normal changing from outside air to recirculate. Also the defrost button will sometimes turn on the windshield defroster with 1 push then turn on the rear defroster with a second push and both will go off on the 3rd push. Other times both defrost buttons will do nothing or work normally. When the wheel buttons are acting up the MFD will control both the recirculate and defrost functions normally so I don't think the MFD is the problem. The 12 volt battery has been checked and is good at 12.4 volts and there is no malfunction lights or codes set in the system. All the other buttons on the wheel function normally. Has anybody else had this problem? Any ideas what to check? Thanks, Todd
  2. priusgto
    194
    231
    Northern Arizona
    Wow! nobody has any ideas? Guess I'm on my own on this one.
  3. koolingit
    koolingit Member
    158
    51
    Mocksville NC, USA
    Look at Hybrid_Tom's posts about '2006 steering wheel'. He tracked his problem down to the circuit board the buttons are mounted on. Be very careful working around the air bag.
  4. priusgto
    194
    231
    Northern Arizona
    Thanks koolingit, looks like a good place to start. One thing I noticed is that when the car is first started it acts up more but, after about one or two minutes of driving it acts normal.
