locking car? gen2->gen3 question
Discussion in 'Gen 3 Prius Audio and Electronics' started by GasSaver1, Sep 14, 2012.
  1. GasSaver1
    GasSaver1 Member
    220
    South Florida\Long Island NY
    I just switched from a smartkey gen2 to a smartkey gen3.
    I have a quick question!
    With the gen2 you never had to take the fob out of your pocket even with locking doors. You simply just pressed the little black button on the handle and off you went. Is there a way to trigger the car to lock with a gen3 like this? I tried swiping my finger which would normally unlock the car but nothing.
    Or does the gen3 now require you to dig for a fob and press the button there
  2. sdtundra
    sdtundra Senior Member
    1,314
    194
    Sacramento, CA
    There are small lines on the top and bottom front of the handle. Just put your finger on that "bump" area until you hear the beep.
    TsKarma likes this.
  3. Joshua
    Joshua Junior Member
    56
    Atlanta, GA
    I did not know this!! sweet no more diggin out the key fob.
  4. GasSaver1
    GasSaver1 Member
    220
    thank you!
  5. sdtundra
    1,314
    194
    Sacramento, CA
    Yeah, switching from my 08 it took me a while to figure this out...i actually read it on here and tried it and it worked.
  6. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Is there a way to set it to auto lock after you exit with the fob on you for a set amount of time, in case you forget?
  7. JAYSONE
    JAYSONE Junior Member
    83
    Los Angeles
    As far as I am aware...No. But if I'm wrong please let me know! I've already forgotten to lock mine several times; thankfully in my driveway and not in a public area.
