ECO Mode
Discussion in 'Prius c Main Forum' started by Banjo, Sep 17, 2012.
  1. Banjo
    Banjo Junior Member
    17
    I'm a new owner about 1 month. I have never used the ECO Mode, I average about 52-60 mpg. What advantage do I get using the ECO mode?
  2. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    1) the A/C is 'relaxed' so it is less likely to run while you are loading down the power available, staying in an efficient mode. If you are not using much A/C, this is of limited value.
    2) the throttle is mapped so you have a great deal of sensitivity at early pedal positions. In contrast, Power mode gives you a great deal of sensitivity at pedal positions near the floor. Normal mode does not alter sensitivity with pedal position.
  3. Tracy
    Tracy Member
    171
    101
    Just FYI - there is no power mode on the C. We have "normal," ECO and EV. I've done some passing of turtle cars on two lane highways and been perfectly content with the responsiveness of normal mode (thank goodness).
  4. Archaeo
    Archaeo New Member
    140
    46
    I have found the eco mode to help raise mpg slightly and have had the AC on full blast with no change at all. The AC works great in eco or normal driving. Have used eco in town and on the freeways. I generally take it off to accelerate when getting on the freeway at 70 mph as it seems to accelerate a bit slower in eco. For just fun driving the normal range seems to be a bit more responsive.
  5. KaliforniaKid
    KaliforniaKid 2013 Prius v Five 2012 Priuc c Four
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    I use ECO Mode while in parking lots. Anywhere else the Prius tells me ECO mode is not applicable.
  6. jdz
    jdz Junior Member
    Pasadena, TX
    I think you are confusing ECO mode with EV mode.
  7. KaliforniaKid
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    Huh? That's my cell phone!
    (Yep, sorry about that).
